Плохая точность позиционирования курсора мыши
2site
Сообщение 2site »
Здравствуйте, при подключения комплекта мышь+клавиатура Asus w5000, курсор слишком медленно перемещается по экрану и точность позиционирования курсора не соответствует перемещению мыши. На клавиатуру нареканий нет.
KERNEL] [    3.472661] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.472673] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.473431] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.473529] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.792432] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.922652] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.922663] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.502436] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.638709] usb 1-1.3: New USB device found, idVendor=0b05, idProduct=185e
[        KERNEL] [    4.638720] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.638728] usb 1-1.3: Product: ASUS W5000 Wireless Keyboard Mouse Set
[        KERNEL] [    4.638735] usb 1-1.3: Manufacturer: MOSART Semi.
[        KERNEL] [    4.644105] input: MOSART Semi. ASUS W5000 Wireless Keyboard Mouse Set as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:0B05:185E.0001/input/input0
[        KERNEL] [    4.713890] hid-generic 0003:0B05:185E.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. ASUS W5000 Wireless Keyboard Mouse Set] on usb-3f980000.usb-1.3/input0
[        KERNEL] [    4.724766] input: MOSART Semi. ASUS W5000 Wireless Keyboard Mouse Set as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:0B05:185E.0002/input/input1
[        KERNEL] [    4.803189] hid-generic 0003:0B05:185E.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. ASUS W5000 Wireless Keyboard Mouse Set] on usb-3f980000.usb-1.3/input1
[        initrd] [    5.002846] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
[        initrd] [   41.555251] Hostname: "wtwB827EBB2F496".
RSH: listener is active.
Send broadcast WTCU discover.
[         httpd] [   41.834547] Reread settings.
[         httpd] [   41.834712] Everyone can control terminal by HTTP.
[            gm] [   41.839259] WTware session manager 5.6.22/RPi.
[            gm] [   41.840539] Add keyboard event1: MOSART Semi. ASUS W5000 Wireless Keyboard Mouse Set.
[            gm] [   41.840633] Add keyboard event0: MOSART Semi. ASUS W5000 Wireless Keyboard Mouse Set.
[            gm] [   41.840794] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   41.875926] Framebuffer device found.
[            gm] [   41.876006] LINELENBYTES 7680
[            gm] [   41.876081] VLEN 8294400
[            gm] [   41.912376] Use /lib/ui32.so.
[            gm] [   41.954954] Load usb storage driver.
[            gm] [   41.955078] modprobe scsi_mod.
[        KERNEL] [   41.969571] SCSI subsystem initialized
[            gm] [   41.969889] modprobe usb-storage.
[            gm] [   41.981523] modprobe sd_mod.
[        KERNEL] [   41.982848] usbcore: registered new interface driver usb-storage
[            gm] [   41.991429] Load EXFAT filesystem driver.
[            gm] [   41.991610] modprobe fuse.
[            gm] [   42.003958] modprobe exfat.
[        KERNEL] [   42.004602] fuse init (API version 7.26)
[        KERNEL] [   42.015658] exFAT: Version 1.2.9
[            gm] [   42.099260] Run '/sbin/resolver 0x1ac4c28 dns [192.168.94.24]', log '', env '', pid ''.
[            gm] [   42.099412] Everyone can control terminal by VNC.
[            gm] [   42.099492] [VNC] Listener at port 5900.
[          pfac] [   42.100479] Run /sbin/resolver 0x1ac4c28 dns [192.168.94.24].
[          pfac] [   42.100743] Ok, PID 701.
[          pfac] [   42.105284] Process pid 701 terminated, status 00000000.
Re: Плохая точность позиционирования курсора мыши
https://forum.wtware.ru/viewtopic.php?p=49384#p49384
Если не поможет, тогда гуглить про эту мышь на Raspbian.
Если не нагуглится - взять другую мышь.
