Ноутбук DELL с UEFI не загружается с WTWare сервера.
DHCP дает настройки 67 5.8.8\bootx64.efi
66 ip address
лог с wtware
14-21-35-699| WTware TFTP server v.5.8.8 (c) 2003-2018 WTware http://www.wtware.com
14-21-35-714| Found interface 10.1.3.176/255.255.255.0 mtu 1500 mac 00:50:56:83:45:AD adapter Сетевое подключение Intel(R) 82574L Gigabit.
14-21-35-714| Bind at 0.0.0.0:69.
15-39-22-993| [10.1.20.166] RRQ 33 bytes:
15-39-23-009| [10.1.20.166] 00000000: 35 2e 36 2e 31 36 5c 62 6f 6f 74 78 36 34 2e 65
15-39-23-009| [10.1.20.166] 00000010: 66 69 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30
15-39-23-009| [10.1.20.166] 00000020: 00
15-39-23-009| [10.1.20.166] "5.6.16\bootx64.efi": tsize is requested, blksize default.
15-39-23-024| [10.1.20.166] "5.6.16\bootx64.efi": "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.16\bootx64.efi".
15-39-23-024| [10.1.20.166] Received opcode ERR.
На ноутбуке
NBP is too big to fit in free base memory
проблема с загрузкой машины с UEFI
Re: проблема с загрузкой машины с UEFI
Полный лог терминала пришлите
15-59-21-519| [10.1.20.166] RRQ 33 bytes:
15-59-21-519| [10.1.20.166] 00000000: 35 2e 36 2e 31 36 5c 62 6f 6f 74 78 36 34 2e 65
15-59-21-519| [10.1.20.166] 00000010: 66 69 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30
15-59-21-613| [10.1.20.166] 00000020: 00
15-59-21-628| [10.1.20.166] "5.6.16\bootx64.efi": tsize is requested, blksize default.
15-59-21-628| [10.1.20.166] "5.6.16\bootx64.efi": "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.16\bootx64.efi".
15-59-21-628| [10.1.20.166] Received opcode ERR.
15-59-21-628| Close TCP connection while sending data, errno 0.
15-59-48-839| Connection closed.
15-59-49-141| WTware TFTP server v.5.6.16 (c) 2003-2017 WTware http://www.wtware.com
15-59-49-164| Found interface 10.1.3.191/255.255.255.0 mtu 1500 mac 00:50:56:83:79:19 adapter Сетевое подключение Intel(R) 82574L Gigabit.
15-59-49-167| Bind at 0.0.0.0:69.
16-02-24-175| [10.1.20.166] RRQ 33 bytes:
16-02-24-189| [10.1.20.166] 00000000: 35 2e 36 2e 31 36 5c 62 6f 6f 74 78 36 34 2e 65
16-02-24-190| [10.1.20.166] 00000010: 66 69 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30
16-02-24-201| [10.1.20.166] 00000020: 00
16-02-24-202| [10.1.20.166] "5.6.16\bootx64.efi": tsize is requested, blksize default.
16-02-24-213| [10.1.20.166] "5.6.16\bootx64.efi": "C:\Program Files (x86)\WTware\TFTPDROOT\5.6.16\bootx64.efi".
16-02-24-214| [10.1.20.166] Received opcode ERR.
Вот полный лог.
Или я не так что -то понял?
Вот полный лог.
Я такое сообщение только у обычного, старого legacy биоса видел. Откуда уверенность, что это UEFI?
Возможно, конечно я ошибся с настройкой машины ... перепроверю....
Есть возможность дать ссылку на настройку загрузки машины с UEFI ?
С нашей стороны UEFI от старого биоса только 067 параметром DHCP отличается. 5.8.8\bootx64.efi - правильное значение для 64-битного UEFI.
Часть проблемы вроде пофиксил... точнее нашел как в ручном режиме запускать загрузку.... в UEFI нажимаем на Boot Override и система начинает грузиться проблем нет.... но автоматически не хочет.... видно какая то жесть с биосом\UEFI, но если подскажете куда копать буду благодарен....
В сторону обновления биоса. В сторону задавания вопросов производителю.
Если стало понятно, что проблема в биосе, то мы как можем помочь??
