smartcard Avtor
Birder
smartcard Avtor
Сообщение Birder »
Добрый день. Подскажите пожалуйста: не пробрасывается смарт-карта avtor. Пробовал просто через виндовый рдп клиент - пробрасывается.
В логах wtware вижу rdpdr-scard] [ 19.409632] Reset client 1.
Не пойму что с этим делать. Видовая служба СмартКарт - включена
Спасибо
Кусок лога ниже....
14-01-27-757| [ gm] [ 18.473787] Run scard daemon. Supported cards:
14-01-27-757| [ gm] [ 18.473801] Автоматически определить ридер.
14-01-27-757| [ gm] [ 18.473808] Avtor (15cf:0019).
14-01-27-757| [ pfac] [ 18.474415] Run /sbin/rdpdr[scard] 0.
14-01-27-757| [ gm] [ 18.474425] Run '/sbin/rdpdr[scard] 0', log '/tmp/rdpdr[scard].out', env '', pid ''.
14-01-27-757| [ pfac] [ 18.474434] Ok, PID 945.
14-01-27-757| [ rdpdr-scard] [ 18.474683] RDP Smart Card Redirector, WTware 5.8.22.
14-01-27-757| [ pfac] [ 18.476349] Run /sbin/resolver 0x12c0b28 dns [172.16.106.25].
14-01-27-757| [ gm] [ 18.476358] Run '/sbin/resolver 0x12c0b28 dns [172.16.106.25]', log '', env '', pid ''.
14-01-27-757| [ pfac] [ 18.476366] Ok, PID 946.
14-01-27-757| [ gm] [ 18.476369] Nobody can control terminal by VNC.
14-01-27-757| [ pfac] [ 18.476765] Process pid 946 terminated, status 00000000.
14-01-27-757| [ gm] [ 18.486909] 172.16.106.25 => 172.16.106.25.
14-01-27-757| [ pfac] [ 18.504281] Run /sbin/rdpclient-SSE 1.
14-01-27-757| [ gm] [ 18.504289] Free ram before fork terminal client /sbin/rdpclient-SSE (session 1): 3085320 Kb.
14-01-27-757| [ pfac] [ 18.504296] Ok, PID 947.
14-01-27-757| [ gm] [ 18.504300] Run '/sbin/rdpclient-SSE 1', log '/tmp/rdpclient.out', env '', pid ''.
14-01-27-757| [ rdpclient 947] [ 18.504823] RDP Terminal Client, WTware 5.8.22, pipe 1, pid 947.
14-01-27-757| [ rdpclient 947] [ 18.504880] Use /lib/ui32-SSE.so.
14-01-27-757| [ rdpclient 947] [ 18.504984] Add smartcard redirection.
14-01-27-757| [ rdpdr-scard] [ 18.504997] New client connection, id 1.
14-01-27-757| [ rdpclient 947] [ 18.505001] Make RDP session with 172.16.106.25, port 3389.
14-01-27-757| [ rdpclient 947] [ 18.505008] No username.
14-01-27-757| [ rdpclient 947] [ 18.505014] No password.
14-01-27-757| [ rdpclient 947] [ 18.505020] No PIN.
14-01-27-757| [ rdpclient 947] [ 18.505028] No domain.
14-01-27-757| [ rdpclient 947] [ 18.505037] No shell.
14-01-27-757| [ rdpclient 947] [ 18.505046] No directory.
14-01-27-757| [ rdpclient 947] [ 18.505054] Window: 960x768@24.
14-01-27-757| [ rdpclient 947] [ 18.505061] PFlags 0x0000002F.
14-01-27-757| [ rdpclient 947] [ 18.505067] Keyboard 00000409:00000000.
14-01-27-757| [ rdpclient 947] [ 18.505073] My hostname "wtw1831BF2ECAE4".
14-01-27-757| [ rdpclient 947] [ 18.505079] TCP: connecting to 172.16.106.25:3389.
14-01-27-757| [ rdpclient 947] [ 18.506744] TCP: connection with 172.16.106.25:3389 established.
14-01-27-757| [ rdpclient 947] [ 18.506751] Turn keepalive on.
14-01-27-757| [ rdpclient 947] [ 18.506860] Free ram after buffers allocation: 3084700 KB.
14-01-27-757| [ rdpclient 947] [ 18.512314] Server supports GFX Pipeline.
14-01-27-757| [ rdpclient 947] [ 18.515534] Process RDP server certificate.
14-01-27-757| [ rdpclient 947] [ 18.515541] RDP5 encryption (X.509).
14-01-27-757| [ rdpclient 947] [ 18.520392] Enable font smoothing and Desktop Composition.
14-01-27-757| [ rdpclient 947] [ 18.573451] GFX codec.
14-01-27-757| [ rdpdr-scard] [ 18.953682] Reset client 1.
Re: smartcard Avtor
