Не могу заставить работать 2 монитора
poolk
Сообщение poolk »
Добрый день,
Собственно, сабж.
[        initrd] [   12.387918] Hostname: "wtwE840F2A49B0A".
[        initrd] [   12.484211] Run '/bin/sh /tmp/ntpdate', log '/tmp/ntp.out', env '', pid ''.
[          pfac] [   12.484281] Run /bin/sh /tmp/ntpdate.
RSH: listener is active.
Send broadcast WTCU discover.
[          pfac] [   12.485451] Ok, PID 767.
[           NTP] [   12.486216] ntpd: sending query to 193.106.144.6
[        initrd] [   12.486281] [TFTP] Download and unpack file packages/f from 192.168.0.1.
[         httpd] [   12.486317] Reread settings.
[         httpd] [   12.486357] Everyone can control terminal by HTTP.
[           NTP] [   12.588988] ntpd: reply from 193.106.144.6: offset:-0.020657 delay:0.102636 status:0x24 strat:2 refid:0x44a11c1f rootdelay:0.006989 reach:0x01
[           NTP] [   14.591073] ntpd: sending query to 193.106.144.6
[           NTP] [   14.694643] ntpd: reply from 193.106.144.6: offset:-0.020483 delay:0.101817 status:0x24 strat:2 refid:0x44a11c1f rootdelay:0.006989 reach:0x03
[           NTP] [   14.697078] Sat Nov 10 06:27:53 2018  0.000000 seconds
[          pfac] [   14.697503] Process pid 767 terminated, status 00000000.
[        initrd] [   16.258987] [TFTP] Download and unpack file packages/fwt6 from 192.168.0.1.
[        initrd] [   17.175013] [TFTP] Download and unpack file packages/graphic from 192.168.0.1.
[            gm] [   17.245804] WTware 5.8.22 session manager.
[            gm] [   17.246526] Add keyboard event5:   USB Keyboard.
[            gm] [   17.246585] Add keyboard event4:   USB Keyboard.
[            gm] [   17.246623] Ignore event3: PC Speaker.
[            gm] [   17.280081] Add keyboard event2: Power Button.
[            gm] [   17.280139] Add keyboard event1: Sleep Button.
[            gm] [   17.280190] Add keyboard event0: Power Button.
[            gm] [   17.280269] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 2.
[            gm] [   17.280319] M2 mode: 1024x768, landscape, 0 Hz, modeline "", DDC enabled, connector 1.
[            gm] [   20.428347] modprobe drm.
[        KERNEL] [   20.435859] Linux agpgart interface v0.103
[            gm] [   20.450405] Run modprobe gma500_gfx .
[            gm] [   20.450480] modprobe gma500_gfx.
[        KERNEL] [   20.504705] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[        KERNEL] [   20.505259] acpi device:26: registered as cooling_device5
[        KERNEL] [   20.505453] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input6
[        KERNEL] [   20.505674] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[        KERNEL] [   20.505677] [drm] No driver support for vblank timestamp query.
[        KERNEL] [   20.594351] gma500 0000:00:02.0: trying to get vblank count for disabled pipe 1
[        KERNEL] [   20.594360] gma500 0000:00:02.0: trying to get vblank count for disabled pipe 1
[            gm] [   21.037831] Kernel drm/kms module loaded.
[        KERNEL] [   21.037197] [drm] Initialized gma500 1.0.0 20140314 for 0000:00:02.0 on minor 0
[            gm] [   21.037937] count_fbs 0.
[            gm] [   21.037986] count_crtcs 2.
[            gm] [   21.038035] count_connectors 4.
[            gm] [   21.038083] count_encoders 4.
[            gm] [   21.038131] min_width 0, max_width 4096, min_height 0, max_height 4096.
[            gm] [   21.195032] ======================
[            gm] [   21.195109] connector_id 33.
[            gm] [   21.195164] encoder_id 0.
[            gm] [   21.195207] connector_type VGA (1).
[            gm] [   21.195251] connector_type_id 1.
[            gm] [   21.195294] connection 1.
[            gm] [   21.195337] mm_width 440, mm_height 250.
[            gm] [   21.195380] subpixel 0.
[            gm] [   21.195423] count_modes 19.
[            gm] [   21.195466] count_props 3.
[            gm] [   21.195508] count_encoders 1.
[            gm] [   21.195551] encoders_ptr [34]
[            gm] [   21.195594] ======================
[            gm] [   21.206994] ======================
[            gm] [   21.207049] connector_id 35.
[            gm] [   21.207093] encoder_id 0.
[            gm] [   21.207137] connector_type LVDS (7).
[            gm] [   21.207180] connector_type_id 1.
[            gm] [   21.207222] connection 1.
[            gm] [   21.207265] mm_width 0, mm_height 0.
[            gm] [   21.207308] subpixel 1.
[            gm] [   21.207351] count_modes 1.
[            gm] [   21.207394] count_props 5.
[            gm] [   21.207437] count_encoders 1.
[            gm] [   21.207480] encoders_ptr [36]
[            gm] [   21.207523] ======================
[            gm] [   21.707409] ======================
[            gm] [   21.707477] connector_id 38.
[            gm] [   21.707522] encoder_id 0.
[            gm] [   21.707565] connector_type DVID (3).
[            gm] [   21.707607] connector_type_id 1.
[            gm] [   21.707650] connection 1.
[            gm] [   21.707693] mm_width 480, mm_height 270.
[            gm] [   21.707735] subpixel 1.
[            gm] [   21.707778] count_modes 22.
[            gm] [   21.707820] count_props 4.
[            gm] [   21.707863] count_encoders 1.
[            gm] [   21.707905] encoders_ptr [39]
[            gm] [   21.707948] ======================
[            gm] [   21.708495] ======================
[            gm] [   21.708547] connector_id 40.
[            gm] [   21.708596] encoder_id 0.
[            gm] [   21.708646] connector_type DisplayPort (10).
[            gm] [   21.708695] connector_type_id 1.
[            gm] [   21.708744] connection 2.
[            gm] [   21.708793] mm_width 0, mm_height 0.
[            gm] [   21.708840] subpixel 0.
[            gm] [   21.708884] count_modes 0.
[            gm] [   21.708927] count_props 5.
[            gm] [   21.708970] count_encoders 1.
[            gm] [   21.709013] encoders_ptr [41]
[            gm] [   21.709056] ======================
[            gm] [   21.709099] ======================
[            gm] [   21.709142] crtc_id 28.
[            gm] [   21.709185] fb buffer_id 0 (disconnected from fb).
[            gm] [   21.709228] x 0, y 0.
[            gm] [   21.709271] mode_valid 0.
[            gm] [   21.709314] Mode : clock 0 H 0 0 0 0 0 V 0 0 0 0 0 VR 0 flags 0x0000 type 0x0000.
[            gm] [   21.709357] gamma_size 256.
[            gm] [   21.709400] 0 connectors.
[            gm] [   21.709443] ======================
[            gm] [   21.709486] ======================
[            gm] [   21.709530] crtc_id 30.
[            gm] [   21.709572] fb buffer_id 0 (disconnected from fb).
[            gm] [   21.709615] x 0, y 0.
[            gm] [   21.709658] mode_valid 0.
[            gm] [   21.709700] Mode : clock 0 H 0 0 0 0 0 V 0 0 0 0 0 VR 0 flags 0x0000 type 0x0000.
[            gm] [   21.709744] gamma_size 256.
[            gm] [   21.709786] 0 connectors.
[            gm] [   21.709829] ======================
[            gm] [   21.709872] ======================
[            gm] [   21.709915] encoder_id 34.
[            gm] [   21.709958] encoder_type DAC (1).
[            gm] [   21.710000] crtc_id 0.
[            gm] [   21.710043] possible_crtcs 1.
[            gm] [   21.710086] possible_clones 1.
[            gm] [   21.710129] ======================
[            gm] [   21.710172] ======================
[            gm] [   21.710215] encoder_id 36.
[            gm] [   21.710258] encoder_type LVDS (3).
[            gm] [   21.710309] crtc_id 0.
[            gm] [   21.710352] possible_crtcs 2.
[            gm] [   21.710396] possible_clones 2.
[            gm] [   21.710439] ======================
[            gm] [   21.710482] ======================
[            gm] [   21.710525] encoder_id 39.
[            gm] [   21.710567] encoder_type TMDS (2).
[            gm] [   21.710610] crtc_id 0.
[            gm] [   21.710653] possible_crtcs 3.
[            gm] [   21.710696] possible_clones 4.
[            gm] [   21.710739] ======================
[            gm] [   21.710782] ======================
[            gm] [   21.710825] encoder_id 41.
[            gm] [   21.710868] encoder_type TMDS (2).
[            gm] [   21.710911] crtc_id 0.
[            gm] [   21.710953] possible_crtcs 3.
[            gm] [   21.710996] possible_clones 8.
[            gm] [   21.711039] ======================
[            gm] [   21.711082] Connector Id 38.
[            gm] [   22.207158] Encoder Id 39.
[            gm] [   22.207222] M2 Connector Id 33.
[            gm] [   22.504518] M2 Encoder Id 34.
[            gm] [   22.504589] M2 CRTC Id 28.
[            gm] [   22.504638] CRTC Id 30.
[            gm] [   22.504686] Force 60Hz refresh.
[            gm] [   22.504734] Mode 1920x1080: clock 148500 H 1920 2008 2052 2200 0 V 1080 1084 1089 1125 0 VR 60 flags 0x0005 type 0x0048.
[            gm] [   22.504782] ^^^ Use this mode ^^^.
[            gm] [   22.504829] Mode 1600x1200: clock 162000 H 1600 1664 1856 2160 0 V 1200 1201 1204 1250 0 VR 60 flags 0x0005 type 0x0040.
[            gm] [   22.504878] Mode 1680x1050: clock 119000 H 1680 1728 1760 1840 0 V 1050 1053 1059 1080 0 VR 60 flags 0x0009 type 0x0040.
[            gm] [   22.504928] Mode 1280x1024: clock 135000 H 1280 1296 1440 1688 0 V 1024 1025 1028 1066 0 VR 75 flags 0x0005 type 0x0040.
[            gm] [   22.504978] Mode 1280x1024: clock 108000 H 1280 1328 1440 1688 0 V 1024 1025 1028 1066 0 VR 60 flags 0x0005 type 0x0040.
[            gm] [   22.505027] Mode 1440x900: clock 88750 H 1440 1488 1520 1600 0 V 900 903 909 926 0 VR 60 flags 0x0009 type 0x0040.
[            gm] [   22.505077] Mode 1280x960: clock 108000 H 1280 1376 1488 1800 0 V 960 961 964 1000 0 VR 60 flags 0x0005 type 0x0040.
[            gm] [   22.505126] Mode 1152x864: clock 108000 H 1152 1216 1344 1600 0 V 864 865 868 900 0 VR 75 flags 0x0005 type 0x0040.
[            gm] [   22.505179] Mode 1280x720: clock 74250 H 1280 1390 1430 1650 0 V 720 725 730 750 0 VR 60 flags 0x0005 type 0x0040.
[            gm] [   22.505236] Mode 1024x768: clock 78750 H 1024 1040 1136 1312 0 V 768 769 772 800 0 VR 75 flags 0x0005 type 0x0040.
[            gm] [   22.505296] Mode 1024x768: clock 75000 H 1024 1048 1184 1328 0 V 768 771 777 806 0 VR 70 flags 0x000a type 0x0040.
[            gm] [   22.505363] Mode 1024x768: clock 65000 H 1024 1048 1184 1344 0 V 768 771 777 806 0 VR 60 flags 0x000a type 0x0040.
[            gm] [   22.505439] Mode 832x624: clock 57284 H 832 864 928 1152 0 V 624 625 628 667 0 VR 75 flags 0x000a type 0x0040.
[            gm] [   22.505525] Mode 800x600: clock 49500 H 800 816 896 1056 0 V 600 601 604 625 0 VR 75 flags 0x0005 type 0x0040.
[            gm] [   22.505627] Mode 800x600: clock 50000 H 800 856 976 1040 0 V 600 637 643 666 0 VR 72 flags 0x0005 type 0x0040.
[            gm] [   22.505743] Mode 800x600: clock 40000 H 800 840 968 1056 0 V 600 601 605 628 0 VR 60 flags 0x0005 type 0x0040.
[            gm] [   22.505857] Mode 800x600: clock 36000 H 800 824 896 1024 0 V 600 601 603 625 0 VR 56 flags 0x0005 type 0x0040.
[            gm] [   22.505966] Mode 640x480: clock 31500 H 640 656 720 840 0 V 480 481 484 500 0 VR 75 flags 0x000a type 0x0040.
[            gm] [   22.506086] Mode 640x480: clock 31500 H 640 664 704 832 0 V 480 489 492 520 0 VR 73 flags 0x000a type 0x0040.
[            gm] [   22.506207] Mode 640x480: clock 30240 H 640 704 768 864 0 V 480 483 486 525 0 VR 67 flags 0x000a type 0x0040.
[            gm] [   22.506327] Mode 640x480: clock 25175 H 640 656 752 800 0 V 480 490 492 525 0 VR 60 flags 0x000a type 0x0040.
[            gm] [   22.506465] Mode 720x400: clock 28320 H 720 738 846 900 0 V 400 412 414 449 0 VR 70 flags 0x0006 type 0x0040.
[            gm] [   22.506595] Once more, choose this mode:
[            gm] [   22.506722] Mode 1920x1080: clock 148500 H 1920 2008 2052 2200 0 V 1080 1084 1089 1125 0 VR 60 flags 0x0005 type 0x0048.
[            gm] [   22.506849] fb_ptr 0xa74e5000
[            gm] [   22.506977] stride 7680.
[            gm] [   22.507106] size 8294400.
[            gm] [   22.507230] handle 0x00000001.
[            gm] [   22.525547] ======================
[            gm] [   22.525628] fb_id    0.
[            gm] [   22.525672] width    1920.
[            gm] [   22.525716] height   1080.
[            gm] [   22.525759] pitch    7680.
[            gm] [   22.525802] bpp      32.
[            gm] [   22.525845] depth    24.
[            gm] [   22.525888] handle 0x00000001.
[            gm] [   22.525931] ======================
[            gm] [   23.224819] LINELENBYTES 7680, VBUF 0x0xa74e5000.
[            gm] [   23.224888] Force 60Hz refresh.
[            gm] [   23.224937] Mode 1600x900: clock 108000 H 1600 1624 1704 1800 0 V 900 901 904 1000 0 VR 60 flags 0x0005 type 0x0048.
[            gm] [   23.224986] Mode 1440x900: clock 136750 H 1440 1536 1688 1936 0 V 900 903 909 942 0 VR 75 flags 0x0006 type 0x0040.
[            gm] [   23.225034] Mode 1440x900: clock 106500 H 1440 1520 1672 1904 0 V 900 903 909 934 0 VR 60 flags 0x0006 type 0x0040.
[            gm] [   23.225082] Mode 1280x800: clock 83500 H 1280 1352 1480 1680 0 V 800 803 809 831 0 VR 60 flags 0x0006 type 0x0040.
[            gm] [   23.225133] Mode 1152x864: clock 108000 H 1152 1216 1344 1600 0 V 864 865 868 900 0 VR 75 flags 0x0005 type 0x0040.
[            gm] [   23.225184] Mode 1280x720: clock 74250 H 1280 1390 1430 1650 0 V 720 725 730 750 0 VR 60 flags 0x0005 type 0x0040.
[            gm] [   23.225232] Mode 1024x768: clock 78750 H 1024 1040 1136 1312 0 V 768 769 772 800 0 VR 75 flags 0x0005 type 0x0040.
[            gm] [   23.225281] Mode 1024x768: clock 75000 H 1024 1048 1184 1328 0 V 768 771 777 806 0 VR 70 flags 0x000a type 0x0040.
[            gm] [   23.225331] Mode 1024x768: clock 65000 H 1024 1048 1184 1344 0 V 768 771 777 806 0 VR 60 flags 0x000a type 0x0040.
[            gm] [   23.225380] ^^^ Use this mode ^^^.
[            gm] [   23.225432] Mode 832x624: clock 57284 H 832 864 928 1152 0 V 624 625 628 667 0 VR 75 flags 0x000a type 0x0040.
[            gm] [   23.225484] Mode 800x600: clock 49500 H 800 816 896 1056 0 V 600 601 604 625 0 VR 75 flags 0x0005 type 0x0040.
[            gm] [   23.225539] Mode 800x600: clock 50000 H 800 856 976 1040 0 V 600 637 643 666 0 VR 72 flags 0x0005 type 0x0040.
[            gm] [   23.225600] Mode 800x600: clock 40000 H 800 840 968 1056 0 V 600 601 605 628 0 VR 60 flags 0x0005 type 0x0040.
[            gm] [   23.225678] Mode 800x600: clock 36000 H 800 824 896 1024 0 V 600 601 603 625 0 VR 56 flags 0x0005 type 0x0040.
[            gm] [   23.225766] Mode 640x480: clock 31500 H 640 656 720 840 0 V 480 481 484 500 0 VR 75 flags 0x000a type 0x0040.
[            gm] [   23.225869] Mode 640x480: clock 31500 H 640 664 704 832 0 V 480 489 492 520 0 VR 73 flags 0x000a type 0x0040.
[            gm] [   23.225979] Mode 640x480: clock 30240 H 640 704 768 864 0 V 480 483 486 525 0 VR 67 flags 0x000a type 0x0040.
[            gm] [   23.226103] Mode 640x480: clock 25175 H 640 656 752 800 0 V 480 490 492 525 0 VR 60 flags 0x000a type 0x0040.
[            gm] [   23.226238] Mode 720x400: clock 28320 H 720 738 846 900 0 V 400 412 414 449 0 VR 70 flags 0x0006 type 0x0040.
[            gm] [   23.226369] Once more, choose this mode:
[            gm] [   23.226493] Mode 1024x768: clock 65000 H 1024 1048 1184 1344 0 V 768 771 777 806 0 VR 60 flags 0x000a type 0x0040.
[            gm] [   23.226626] fb_ptr 0xa71e5000
[            gm] [   23.226762] stride 4096.
[            gm] [   23.226895] size 3145728.
[            gm] [   23.227032] handle 0x00000002.
[            gm] [   23.242454] ======================
[            gm] [   23.242544] fb_id    0.
[            gm] [   23.242589] width    1024.
[            gm] [   23.242633] height   768.
[            gm] [   23.242676] pitch    4096.
[            gm] [   23.242719] bpp      32.
[            gm] [   23.242762] depth    24.
[            gm] [   23.242805] handle 0x00000002.
[            gm] [   23.242848] ======================
[            gm] [   23.806073] M2 LINELENBYTES 4096, VBUF 0x0xa71e5000.
[            gm] [   23.806713] Use /lib/ui32.so.
[            gm] [   23.970140] WMEMCOPY: 81000K copied in 0.082680 sec.
[            gm] [   24.568285] libc: 81000K copied in 0.598109 sec.
[            gm] [   24.867575] movs: 81000K copied in 0.299232 sec.
[            gm] [   25.047990] MMX: 81000K copied in 0.180378 sec.
[            gm] [   25.363058] SSE2: 81000K copied in 0.315034 sec.
[            gm] [   25.363187] Choose WMEMCOPY memcpy.
[            gm] [   25.539970] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [   25.548249] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[            gm] [   25.548285] Nobody can control terminal by VNC.
[          pfac] [   25.548340] Ok, PID 819.
[            gm] [   25.548371] Add keyboard event6: Video Bus.
[          pfac] [   25.548436] Process pid 819 terminated, status 00000000.
[            gm] [   25.548468] 192.168.0.115 => 192.168.0.115.
[            gm] [   25.601949] Free ram before fork terminal client /sbin/rdpclient-SSE (session 1): 3044712 Kb.
[          pfac] [   25.602030] Run /sbin/rdpclient-SSE 1.
[            gm] [   25.602057] Run '/sbin/rdpclient-SSE 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   25.602094] Ok, PID 820.
[ rdpclient 820] [   25.615737] RDP Terminal Client, WTware 5.8.22, pipe 1, pid 820.
[ rdpclient 820] [   25.616102] Use /lib/ui32-SSE.so.
[ rdpclient 820] [   25.616552] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 820] [   25.616728]  No username.
[ rdpclient 820] [   25.616804]  No password.
[ rdpclient 820] [   25.616859]  No PIN.
[ rdpclient 820] [   25.616909]  No domain.
[ rdpclient 820] [   25.616961]  No shell.
[ rdpclient 820] [   25.617015]  No directory.
[ rdpclient 820] [   25.617066]  Window: 1920x1080@24.
[ rdpclient 820] [   25.617116]  Second monitor: [1920:0..2943:767].
[ rdpclient 820] [   25.617172]  PFlags 0x0000002F.
[ rdpclient 820] [   25.617226]  Keyboard 00000409:00000000.
[ rdpclient 820] [   25.617287]  My hostname "wtwE840F2A49B0A".
[ rdpclient 820] [   25.617341] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 820] [   25.617745] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 820] [   25.617896] Turn keepalive on.
[ rdpclient 820] [   25.618316] Free ram after buffers allocation: 3044084 KB.
[            gm] [   25.621484] DRM ioctl failed with -1, errno 38.
[            gm] [   25.621602] No more DRM_IOCTL_MODE_DIRTYFB calls.
[ rdpclient 820] [   25.628574] Server supports GFX Pipeline.
[ rdpclient 820] [   25.628713] Process RDP server certificate.
[ rdpclient 820] [   25.636941] RDP5 encryption (X.509).
[ rdpclient 820] [   25.639680] Enable font smoothing and Desktop Composition.
[        KERNEL] [   25.639042] random: rdpclient-SSE: uninitialized urandom read (32 bytes read)
[ rdpclient 820] [   25.720257] GFX codec.
[        KERNEL] [   25.721598] random: crng init done
[ rdpclient 820] [   26.251683] Run 4 tile threads.
[ rdpclient 820] [   57.441157] errorInfo 0x0000000c.
[ rdpclient 820] [   57.441224] ERRINFO_LOGOFF_BY_USER
[ rdpclient 820] [   57.546146] Receive Disconnect Provider Ultimatum.
[            gm] [   57.546212] TSClient (sessionId 1, pid 820) gracefully end.
[          pfac] [   57.550725] Process pid 820 terminated, status 00000009.
[            gm] [   57.557636] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [   57.557782] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [   57.558052] Ok, PID 830.
[          pfac] [   57.568365] Process pid 830 terminated, status 00000000.
[            gm] [   57.586030] 192.168.0.115 => 192.168.0.115.
[            gm] [   57.616292] Free ram before fork terminal client /sbin/rdpclient-SSE (session 2): 3045564 Kb.
[            gm] [   57.616342] Run '/sbin/rdpclient-SSE 2', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   57.616380] Run /sbin/rdpclient-SSE 2.
[          pfac] [   57.616494] Ok, PID 831.
[ rdpclient 831] [   57.618944] RDP Terminal Client, WTware 5.8.22, pipe 2, pid 831.
[ rdpclient 831] [   57.619365] Use /lib/ui32-SSE.so.
[ rdpclient 831] [   57.619825] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 831] [   57.619923]  No username.
[ rdpclient 831] [   57.619991]  No password.
[ rdpclient 831] [   57.620078]  No PIN.
[ rdpclient 831] [   57.620118]  No domain.
[ rdpclient 831] [   57.620156]  No shell.
[ rdpclient 831] [   57.620292]  No directory.
[ rdpclient 831] [   57.620368]  Window: 1920x1080@24.
[ rdpclient 831] [   57.620431]  Second monitor: [1920:0..2943:767].
[ rdpclient 831] [   57.620488]  PFlags 0x0000002F.
[ rdpclient 831] [   57.620549]  Keyboard 00000409:00000000.
[ rdpclient 831] [   57.620635]  My hostname "wtwE840F2A49B0A".
[ rdpclient 831] [   57.620695] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 831] [   57.620752] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 831] [   57.620816] Turn keepalive on.
[ rdpclient 831] [   57.621193] Free ram after buffers allocation: 3044696 KB.
[ rdpclient 831] [   57.626098] Server supports GFX Pipeline.
[ rdpclient 831] [   57.630141] Process RDP server certificate.
[ rdpclient 831] [   57.630209] RDP5 encryption (X.509).
[ rdpclient 831] [   57.634018] Enable font smoothing and Desktop Composition.
[ rdpclient 831] [   57.693753] GFX codec.
[ rdpclient 831] [   58.170298] Run 4 tile threads.
[ rdpclient 831] [   89.277917] errorInfo 0x0000000c.
[ rdpclient 831] [   89.278046] ERRINFO_LOGOFF_BY_USER
[ rdpclient 831] [   89.381595] Receive Disconnect Provider Ultimatum.
[            gm] [   89.416505] TSClient (sessionId 2, pid 831) gracefully end.
[          pfac] [   89.467707] Process pid 831 terminated, status 00000009.
[            gm] [   89.488275] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [   89.488367] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [   89.488587] Ok, PID 842.
[          pfac] [   89.494528] Process pid 842 terminated, status 00000000.
[            gm] [   89.535783] 192.168.0.115 => 192.168.0.115.
[            gm] [   89.700301] Free ram before fork terminal client /sbin/rdpclient-SSE (session 3): 3045196 Kb.
[            gm] [   89.700356] Run '/sbin/rdpclient-SSE 3', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   89.700396] Run /sbin/rdpclient-SSE 3.
[          pfac] [   89.700489] Ok, PID 843.
[ rdpclient 843] [   89.702937] RDP Terminal Client, WTware 5.8.22, pipe 3, pid 843.
[ rdpclient 843] [   89.703358] Use /lib/ui32-SSE.so.
[ rdpclient 843] [   89.703837] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 843] [   89.703943]  No username.
[ rdpclient 843] [   89.704032]  No password.
[ rdpclient 843] [   89.704082]  No PIN.
[ rdpclient 843] [   89.704121]  No domain.
[ rdpclient 843] [   89.704159]  No shell.
[ rdpclient 843] [   89.704197]  No directory.
[ rdpclient 843] [   89.704235]  Window: 1920x1080@24.
[ rdpclient 843] [   89.704273]  Second monitor: [1920:0..2943:767].
[ rdpclient 843] [   89.704315]  PFlags 0x0000002F.
[ rdpclient 843] [   89.704367]  Keyboard 00000409:00000000.
[ rdpclient 843] [   89.704424]  My hostname "wtwE840F2A49B0A".
[ rdpclient 843] [   89.704481] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 843] [   89.704540] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 843] [   89.704596] Turn keepalive on.
[ rdpclient 843] [   89.705229] Free ram after buffers allocation: 3044452 KB.
[ rdpclient 843] [   89.714043] Server supports GFX Pipeline.
[ rdpclient 843] [   89.716061] Process RDP server certificate.
[ rdpclient 843] [   89.716133] RDP5 encryption (X.509).
[ rdpclient 843] [   89.721500] Enable font smoothing and Desktop Composition.
[ rdpclient 843] [   89.791786] GFX codec.
[ rdpclient 843] [   90.280854] Run 4 tile threads.
[ rdpclient 843] [  121.478987] errorInfo 0x0000000c.
[ rdpclient 843] [  121.479056] ERRINFO_LOGOFF_BY_USER
[ rdpclient 843] [  121.583113] Receive Disconnect Provider Ultimatum.
[            gm] [  121.585244] TSClient (sessionId 3, pid 843) gracefully end.
[          pfac] [  121.602489] Process pid 843 terminated, status 00000009.
[            gm] [  121.615518] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  121.615654] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  121.615929] Ok, PID 850.
[          pfac] [  121.617554] Process pid 850 terminated, status 00000000.
[            gm] [  121.622532] 192.168.0.115 => 192.168.0.115.
[            gm] [  121.656300] Free ram before fork terminal client /sbin/rdpclient-SSE (session 4): 3045188 Kb.
[            gm] [  121.656354] Run '/sbin/rdpclient-SSE 4', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  121.656392] Run /sbin/rdpclient-SSE 4.
[          pfac] [  121.656488] Ok, PID 851.
[ rdpclient 851] [  121.662360] RDP Terminal Client, WTware 5.8.22, pipe 4, pid 851.
[ rdpclient 851] [  121.662795] Use /lib/ui32-SSE.so.
[ rdpclient 851] [  121.663283] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 851] [  121.663380]  No username.
[ rdpclient 851] [  121.663441]  No password.
[ rdpclient 851] [  121.663489]  No PIN.
[ rdpclient 851] [  121.663527]  No domain.
[ rdpclient 851] [  121.663565]  No shell.
[ rdpclient 851] [  121.663603]  No directory.
[ rdpclient 851] [  121.663769]  Window: 1920x1080@24.
[ rdpclient 851] [  121.663829]  Second monitor: [1920:0..2943:767].
[ rdpclient 851] [  121.663888]  PFlags 0x0000002F.
[ rdpclient 851] [  121.663947]  Keyboard 00000409:00000000.
[ rdpclient 851] [  121.664039]  My hostname "wtwE840F2A49B0A".
[ rdpclient 851] [  121.664109] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 851] [  121.664178] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 851] [  121.664254] Turn keepalive on.
[ rdpclient 851] [  121.664658] Free ram after buffers allocation: 3044444 KB.
[ rdpclient 851] [  121.670227] Server supports GFX Pipeline.
[ rdpclient 851] [  121.678673] Process RDP server certificate.
[ rdpclient 851] [  121.678741] RDP5 encryption (X.509).
[ rdpclient 851] [  121.701245] Enable font smoothing and Desktop Composition.
[ rdpclient 851] [  121.769221] GFX codec.
[ rdpclient 851] [  122.281629] Run 4 tile threads.
[ rdpclient 851] [  153.377808] errorInfo 0x0000000c.
[ rdpclient 851] [  153.377896] ERRINFO_LOGOFF_BY_USER
[ rdpclient 851] [  153.478640] Receive Disconnect Provider Ultimatum.
[            gm] [  153.492049] TSClient (sessionId 4, pid 851) gracefully end.
[          pfac] [  153.500544] Process pid 851 terminated, status 00000009.
[            gm] [  153.504070] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  153.504187] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  153.512895] Process pid 858 terminated, status 00000000.
[          pfac] [  153.513016] Ok, PID 858.
[            gm] [  153.518940] 192.168.0.115 => 192.168.0.115.
[            gm] [  153.548299] Free ram before fork terminal client /sbin/rdpclient-SSE (session 5): 3045436 Kb.
[            gm] [  153.548346] Run '/sbin/rdpclient-SSE 5', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  153.548384] Run /sbin/rdpclient-SSE 5.
[          pfac] [  153.548489] Ok, PID 859.
[ rdpclient 859] [  153.550964] RDP Terminal Client, WTware 5.8.22, pipe 5, pid 859.
[ rdpclient 859] [  153.551394] Use /lib/ui32-SSE.so.
[ rdpclient 859] [  153.551877] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 859] [  153.551980]  No username.
[ rdpclient 859] [  153.552078]  No password.
[ rdpclient 859] [  153.552127]  No PIN.
[ rdpclient 859] [  153.552166]  No domain.
[ rdpclient 859] [  153.552217]  No shell.
[ rdpclient 859] [  153.552255]  No directory.
[ rdpclient 859] [  153.552293]  Window: 1920x1080@24.
[ rdpclient 859] [  153.552336]  Second monitor: [1920:0..2943:767].
[ rdpclient 859] [  153.552390]  PFlags 0x0000002F.
[ rdpclient 859] [  153.552447]  Keyboard 00000409:00000000.
[ rdpclient 859] [  153.552502]  My hostname "wtwE840F2A49B0A".
[ rdpclient 859] [  153.552556] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 859] [  153.552615] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 859] [  153.552675] Turn keepalive on.
[ rdpclient 859] [  153.553254] Free ram after buffers allocation: 3044692 KB.
[ rdpclient 859] [  153.558929] Server supports GFX Pipeline.
[ rdpclient 859] [  153.560941] Process RDP server certificate.
[ rdpclient 859] [  153.561001] RDP5 encryption (X.509).
[ rdpclient 859] [  153.565006] Enable font smoothing and Desktop Composition.
[ rdpclient 859] [  153.623672] GFX codec.
[ rdpclient 859] [  154.058166] Run 4 tile threads.
[ rdpclient 859] [  185.199724] errorInfo 0x0000000c.
[ rdpclient 859] [  185.199793] ERRINFO_LOGOFF_BY_USER
[ rdpclient 859] [  185.306264] Receive Disconnect Provider Ultimatum.
[            gm] [  185.306334] TSClient (sessionId 5, pid 859) gracefully end.
[          pfac] [  185.310793] Process pid 859 terminated, status 00000009.
[            gm] [  185.317734] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  185.317871] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  185.318131] Ok, PID 866.
[          pfac] [  185.319676] Process pid 866 terminated, status 00000000.
[            gm] [  185.324722] 192.168.0.115 => 192.168.0.115.
[            gm] [  185.352301] Free ram before fork terminal client /sbin/rdpclient-SSE (session 6): 3045188 Kb.
[            gm] [  185.352348] Run '/sbin/rdpclient-SSE 6', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  185.352386] Run /sbin/rdpclient-SSE 6.
[          pfac] [  185.352500] Ok, PID 867.
[ rdpclient 867] [  185.354946] RDP Terminal Client, WTware 5.8.22, pipe 6, pid 867.
[ rdpclient 867] [  185.355361] Use /lib/ui32-SSE.so.
[ rdpclient 867] [  185.355847] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 867] [  185.355944]  No username.
[ rdpclient 867] [  185.356034]  No password.
[ rdpclient 867] [  185.356089]  No PIN.
[ rdpclient 867] [  185.356128]  No domain.
[ rdpclient 867] [  185.356166]  No shell.
[ rdpclient 867] [  185.356204]  No directory.
[ rdpclient 867] [  185.356340]  Window: 1920x1080@24.
[ rdpclient 867] [  185.356410]  Second monitor: [1920:0..2943:767].
[ rdpclient 867] [  185.356467]  PFlags 0x0000002F.
[ rdpclient 867] [  185.356525]  Keyboard 00000409:00000000.
[ rdpclient 867] [  185.356606]  My hostname "wtwE840F2A49B0A".
[ rdpclient 867] [  185.356668] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 867] [  185.356731] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 867] [  185.356794] Turn keepalive on.
[ rdpclient 867] [  185.357218] Free ram after buffers allocation: 3044444 KB.
[ rdpclient 867] [  185.361309] Server supports GFX Pipeline.
[ rdpclient 867] [  185.363631] Process RDP server certificate.
[ rdpclient 867] [  185.363691] RDP5 encryption (X.509).
[ rdpclient 867] [  185.367444] Enable font smoothing and Desktop Composition.
[ rdpclient 867] [  185.436432] GFX codec.
[ rdpclient 867] [  185.909591] Run 4 tile threads.
[ rdpclient 867] [  217.018904] errorInfo 0x0000000c.
[ rdpclient 867] [  217.019027] ERRINFO_LOGOFF_BY_USER
[ rdpclient 867] [  217.129437] Receive Disconnect Provider Ultimatum.
[            gm] [  217.129506] TSClient (sessionId 6, pid 867) gracefully end.
[          pfac] [  217.138146] Process pid 867 terminated, status 00000009.
[            gm] [  217.141497] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  217.141633] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  217.141887] Ok, PID 874.
[          pfac] [  217.143389] Process pid 874 terminated, status 00000000.
[            gm] [  217.148459] 192.168.0.115 => 192.168.0.115.
[            gm] [  217.176301] Free ram before fork terminal client /sbin/rdpclient-SSE (session 7): 3045312 Kb.
[            gm] [  217.176348] Run '/sbin/rdpclient-SSE 7', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  217.176386] Run /sbin/rdpclient-SSE 7.
[          pfac] [  217.176493] Ok, PID 875.
[ rdpclient 875] [  217.178938] RDP Terminal Client, WTware 5.8.22, pipe 7, pid 875.
[ rdpclient 875] [  217.179356] Use /lib/ui32-SSE.so.
[ rdpclient 875] [  217.179845] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 875] [  217.179940]  No username.
[ rdpclient 875] [  217.180036]  No password.
[ rdpclient 875] [  217.180085]  No PIN.
[ rdpclient 875] [  217.180124]  No domain.
[ rdpclient 875] [  217.180162]  No shell.
[ rdpclient 875] [  217.180200]  No directory.
[ rdpclient 875] [  217.180238]  Window: 1920x1080@24.
[ rdpclient 875] [  217.180276]  Second monitor: [1920:0..2943:767].
[ rdpclient 875] [  217.180418]  PFlags 0x0000002F.
[ rdpclient 875] [  217.180480]  Keyboard 00000409:00000000.
[ rdpclient 875] [  217.180540]  My hostname "wtwE840F2A49B0A".
[ rdpclient 875] [  217.180602] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 875] [  217.180691] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 875] [  217.180751] Turn keepalive on.
[ rdpclient 875] [  217.181238] Free ram after buffers allocation: 3044568 KB.
[ rdpclient 875] [  217.186569] Server supports GFX Pipeline.
[ rdpclient 875] [  217.188742] Process RDP server certificate.
[ rdpclient 875] [  217.188804] RDP5 encryption (X.509).
[ rdpclient 875] [  217.192541] Enable font smoothing and Desktop Composition.
[ rdpclient 875] [  217.269420] GFX codec.
[ rdpclient 875] [  217.711457] Run 4 tile threads.
[ rdpclient 875] [  249.598944] errorInfo 0x0000000c.
[ rdpclient 875] [  249.599013] ERRINFO_LOGOFF_BY_USER
[ rdpclient 875] [  249.708843] Receive Disconnect Provider Ultimatum.
[            gm] [  249.708918] TSClient (sessionId 7, pid 875) gracefully end.
[          pfac] [  249.712941] Process pid 875 terminated, status 00000009.
[            gm] [  249.720335] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  249.720474] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  249.720740] Ok, PID 882.
[          pfac] [  249.722290] Process pid 882 terminated, status 00000000.
[            gm] [  249.727334] 192.168.0.115 => 192.168.0.115.
[            gm] [  249.756299] Free ram before fork terminal client /sbin/rdpclient-SSE (session 8): 3045188 Kb.
[            gm] [  249.756348] Run '/sbin/rdpclient-SSE 8', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  249.756387] Run /sbin/rdpclient-SSE 8.
[          pfac] [  249.756502] Ok, PID 883.
[ rdpclient 883] [  249.758932] RDP Terminal Client, WTware 5.8.22, pipe 8, pid 883.
[ rdpclient 883] [  249.759362] Use /lib/ui32-SSE.so.
[ rdpclient 883] [  249.759856] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 883] [  249.759961]  No username.
[ rdpclient 883] [  249.760052]  No password.
[ rdpclient 883] [  249.760104]  No PIN.
[ rdpclient 883] [  249.760143]  No domain.
[ rdpclient 883] [  249.760182]  No shell.
[ rdpclient 883] [  249.760220]  No directory.
[ rdpclient 883] [  249.760258]  Window: 1920x1080@24.
[ rdpclient 883] [  249.760296]  Second monitor: [1920:0..2943:767].
[ rdpclient 883] [  249.760334]  PFlags 0x0000002F.
[ rdpclient 883] [  249.760495]  Keyboard 00000409:00000000.
[ rdpclient 883] [  249.760577]  My hostname "wtwE840F2A49B0A".
[ rdpclient 883] [  249.760643] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 883] [  249.760704] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 883] [  249.760770] Turn keepalive on.
[ rdpclient 883] [  249.761276] Free ram after buffers allocation: 3044940 KB.
[ rdpclient 883] [  249.772532] Server supports GFX Pipeline.
[ rdpclient 883] [  249.782303] Process RDP server certificate.
[ rdpclient 883] [  249.782382] RDP5 encryption (X.509).
[ rdpclient 883] [  249.795457] Enable font smoothing and Desktop Composition.
[ rdpclient 883] [  250.023823] GFX codec.
[ rdpclient 883] [  250.665672] Run 4 tile threads.
[ rdpclient 883] [  281.721688] errorInfo 0x0000000c.
[ rdpclient 883] [  281.721758] ERRINFO_LOGOFF_BY_USER
[ rdpclient 883] [  281.862526] Receive Disconnect Provider Ultimatum.
[            gm] [  281.862596] TSClient (sessionId 8, pid 883) gracefully end.
[          pfac] [  281.866815] Process pid 883 terminated, status 00000009.
[            gm] [  281.874059] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  281.874195] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  281.874471] Ok, PID 890.
[          pfac] [  281.876034] Process pid 890 terminated, status 00000000.
[            gm] [  281.881031] 192.168.0.115 => 192.168.0.115.
[            gm] [  281.908297] Free ram before fork terminal client /sbin/rdpclient-SSE (session 9): 3045244 Kb.
[            gm] [  281.908346] Run '/sbin/rdpclient-SSE 9', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  281.908383] Run /sbin/rdpclient-SSE 9.
[          pfac] [  281.908493] Ok, PID 891.
[ rdpclient 891] [  281.910943] RDP Terminal Client, WTware 5.8.22, pipe 9, pid 891.
[ rdpclient 891] [  281.911370] Use /lib/ui32-SSE.so.
[ rdpclient 891] [  281.911855] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 891] [  281.911951]  No username.
[ rdpclient 891] [  281.912043]  No password.
[ rdpclient 891] [  281.912093]  No PIN.
[ rdpclient 891] [  281.912132]  No domain.
[ rdpclient 891] [  281.912171]  No shell.
[ rdpclient 891] [  281.912208]  No directory.
[ rdpclient 891] [  281.912246]  Window: 1920x1080@24.
[ rdpclient 891] [  281.912284]  Second monitor: [1920:0..2943:767].
[ rdpclient 891] [  281.912323]  PFlags 0x0000002F.
[ rdpclient 891] [  281.912366]  Keyboard 00000409:00000000.
[ rdpclient 891] [  281.912419]  My hostname "wtwE840F2A49B0A".
[ rdpclient 891] [  281.912479] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 891] [  281.912537] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 891] [  281.912596] Turn keepalive on.
[ rdpclient 891] [  281.913198] Free ram after buffers allocation: 3044492 KB.
[ rdpclient 891] [  281.927547] Server supports GFX Pipeline.
[ rdpclient 891] [  281.931005] Process RDP server certificate.
[ rdpclient 891] [  281.931065] RDP5 encryption (X.509).
[ rdpclient 891] [  281.934656] Enable font smoothing and Desktop Composition.
[ rdpclient 891] [  282.122256] GFX codec.
[ rdpclient 891] [  282.793365] Run 4 tile threads.
[ rdpclient 891] [  313.774249] errorInfo 0x0000000c.
[ rdpclient 891] [  313.774317] ERRINFO_LOGOFF_BY_USER
[ rdpclient 891] [  313.879252] Receive Disconnect Provider Ultimatum.
[            gm] [  313.879317] TSClient (sessionId 9, pid 891) gracefully end.
[          pfac] [  313.888179] Process pid 891 terminated, status 00000009.
[            gm] [  313.891268] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  313.891406] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  313.891658] Ok, PID 898.
[          pfac] [  313.893243] Process pid 898 terminated, status 00000000.
[            gm] [  313.898258] 192.168.0.115 => 192.168.0.115.
[            gm] [  313.928297] Free ram before fork terminal client /sbin/rdpclient-SSE (session 10): 3044568 Kb.
[            gm] [  313.928345] Run '/sbin/rdpclient-SSE 10', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  313.928383] Run /sbin/rdpclient-SSE 10.
[          pfac] [  313.928494] Ok, PID 899.
[ rdpclient 899] [  313.930959] RDP Terminal Client, WTware 5.8.22, pipe 10, pid 899.
[ rdpclient 899] [  313.931407] Use /lib/ui32-SSE.so.
[ rdpclient 899] [  313.931873] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 899] [  313.931974]  No username.
[ rdpclient 899] [  313.932076]  No password.
[ rdpclient 899] [  313.932126]  No PIN.
[ rdpclient 899] [  313.932178]  No domain.
[ rdpclient 899] [  313.932216]  No shell.
[ rdpclient 899] [  313.932254]  No directory.
[ rdpclient 899] [  313.932293]  Window: 1920x1080@24.
[ rdpclient 899] [  313.932333]  Second monitor: [1920:0..2943:767].
[ rdpclient 899] [  313.932384]  PFlags 0x0000002F.
[ rdpclient 899] [  313.932442]  Keyboard 00000409:00000000.
[ rdpclient 899] [  313.932502]  My hostname "wtwE840F2A49B0A".
[ rdpclient 899] [  313.932560] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 899] [  313.932620] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 899] [  313.932679] Turn keepalive on.
[ rdpclient 899] [  313.933269] Free ram after buffers allocation: 3043824 KB.
[ rdpclient 899] [  313.937700] Server supports GFX Pipeline.
[ rdpclient 899] [  313.941522] Process RDP server certificate.
[ rdpclient 899] [  313.941586] RDP5 encryption (X.509).
[ rdpclient 899] [  313.945335] Enable font smoothing and Desktop Composition.
[ rdpclient 899] [  314.003699] GFX codec.
[ rdpclient 899] [  314.453743] Run 4 tile threads.
[ rdpclient 899] [  345.599018] errorInfo 0x0000000c.
[ rdpclient 899] [  345.599086] ERRINFO_LOGOFF_BY_USER
[ rdpclient 899] [  345.705912] Receive Disconnect Provider Ultimatum.
[            gm] [  345.705984] TSClient (sessionId 10, pid 899) gracefully end.
[          pfac] [  345.710109] Process pid 899 terminated, status 00000009.
[            gm] [  345.717393] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  345.717525] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  345.717799] Ok, PID 906.
[          pfac] [  345.719378] Process pid 906 terminated, status 00000000.
[            gm] [  345.724409] 192.168.0.115 => 192.168.0.115.
[            gm] [  345.752294] Free ram before fork terminal client /sbin/rdpclient-SSE (session 11): 3044980 Kb.
[            gm] [  345.752342] Run '/sbin/rdpclient-SSE 11', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  345.752380] Run /sbin/rdpclient-SSE 11.
[          pfac] [  345.752485] Ok, PID 907.
[ rdpclient 907] [  345.754942] RDP Terminal Client, WTware 5.8.22, pipe 11, pid 907.
[ rdpclient 907] [  345.755393] Use /lib/ui32-SSE.so.
[ rdpclient 907] [  345.755865] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 907] [  345.755961]  No username.
[ rdpclient 907] [  345.756056]  No password.
[ rdpclient 907] [  345.756121]  No PIN.
[ rdpclient 907] [  345.756162]  No domain.
[ rdpclient 907] [  345.756200]  No shell.
[ rdpclient 907] [  345.756238]  No directory.
[ rdpclient 907] [  345.756277]  Window: 1920x1080@24.
[ rdpclient 907] [  345.756315]  Second monitor: [1920:0..2943:767].
[ rdpclient 907] [  345.756353]  PFlags 0x0000002F.
[ rdpclient 907] [  345.756397]  Keyboard 00000409:00000000.
[ rdpclient 907] [  345.756454]  My hostname "wtwE840F2A49B0A".
[ rdpclient 907] [  345.756513] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 907] [  345.756572] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 907] [  345.756628] Turn keepalive on.
[ rdpclient 907] [  345.757228] Free ram after buffers allocation: 3044236 KB.
[ rdpclient 907] [  345.762990] Server supports GFX Pipeline.
[ rdpclient 907] [  345.764924] Process RDP server certificate.
[ rdpclient 907] [  345.764986] RDP5 encryption (X.509).
[ rdpclient 907] [  345.768530] Enable font smoothing and Desktop Composition.
[ rdpclient 907] [  345.830994] GFX codec.
[ rdpclient 907] [  346.311236] Run 4 tile threads.
[ rdpclient 907] [  377.496809] errorInfo 0x0000000c.
[ rdpclient 907] [  377.496891] ERRINFO_LOGOFF_BY_USER
[ rdpclient 907] [  377.603454] Receive Disconnect Provider Ultimatum.
[            gm] [  377.603541] TSClient (sessionId 11, pid 907) gracefully end.
[          pfac] [  377.607998] Process pid 907 terminated, status 00000009.
[            gm] [  377.614896] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  377.615028] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  377.615268] Ok, PID 914.
[          pfac] [  377.616903] Process pid 914 terminated, status 00000000.
[            gm] [  377.621979] 192.168.0.115 => 192.168.0.115.
[            gm] [  377.652298] Free ram before fork terminal client /sbin/rdpclient-SSE (session 12): 3045128 Kb.
[            gm] [  377.652346] Run '/sbin/rdpclient-SSE 12', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  377.652384] Run /sbin/rdpclient-SSE 12.
[          pfac] [  377.652496] Ok, PID 915.
[ rdpclient 915] [  377.654950] RDP Terminal Client, WTware 5.8.22, pipe 12, pid 915.
[ rdpclient 915] [  377.655369] Use /lib/ui32-SSE.so.
[ rdpclient 915] [  377.655864] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 915] [  377.655967]  No username.
[ rdpclient 915] [  377.656073]  No password.
[ rdpclient 915] [  377.656132]  No PIN.
[ rdpclient 915] [  377.656171]  No domain.
[ rdpclient 915] [  377.656209]  No shell.
[ rdpclient 915] [  377.656247]  No directory.
[ rdpclient 915] [  377.656390]  Window: 1920x1080@24.
[ rdpclient 915] [  377.656461]  Second monitor: [1920:0..2943:767].
[ rdpclient 915] [  377.656520]  PFlags 0x0000002F.
[ rdpclient 915] [  377.656576]  Keyboard 00000409:00000000.
[ rdpclient 915] [  377.656637]  My hostname "wtwE840F2A49B0A".
[ rdpclient 915] [  377.656706] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 915] [  377.656768] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 915] [  377.656831] Turn keepalive on.
[ rdpclient 915] [  377.657262] Free ram after buffers allocation: 3044252 KB.
[ rdpclient 915] [  377.662056] Server supports GFX Pipeline.
[ rdpclient 915] [  377.664232] Process RDP server certificate.
[ rdpclient 915] [  377.664294] RDP5 encryption (X.509).
[ rdpclient 915] [  377.667814] Enable font smoothing and Desktop Composition.
[ rdpclient 915] [  377.724096] GFX codec.
[ rdpclient 915] [  378.265099] Run 4 tile threads.
[ rdpclient 915] [  409.316413] errorInfo 0x0000000c.
[ rdpclient 915] [  409.316483] ERRINFO_LOGOFF_BY_USER
[ rdpclient 915] [  409.420315] Receive Disconnect Provider Ultimatum.
[            gm] [  409.420392] TSClient (sessionId 12, pid 915) gracefully end.
[          pfac] [  409.424693] Process pid 915 terminated, status 00000009.
[            gm] [  409.431750] Run '/sbin/resolver 0xd34ca8 dns [192.168.0.115]', log '', env '', pid ''.
[          pfac] [  409.431887] Run /sbin/resolver 0xd34ca8 dns [192.168.0.115].
[          pfac] [  409.432193] Ok, PID 922.
[          pfac] [  409.433715] Process pid 922 terminated, status 00000000.
[            gm] [  409.438834] 192.168.0.115 => 192.168.0.115.
[            gm] [  409.468296] Free ram before fork terminal client /sbin/rdpclient-SSE (session 13): 3044912 Kb.
[            gm] [  409.468343] Run '/sbin/rdpclient-SSE 13', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [  409.468383] Run /sbin/rdpclient-SSE 13.
[          pfac] [  409.468490] Ok, PID 923.
[ rdpclient 923] [  409.470941] RDP Terminal Client, WTware 5.8.22, pipe 13, pid 923.
[ rdpclient 923] [  409.471385] Use /lib/ui32-SSE.so.
[ rdpclient 923] [  409.471874] Make RDP session with 192.168.0.115, port 3389.
[ rdpclient 923] [  409.471975]  No username.
[ rdpclient 923] [  409.472081]  No password.
[ rdpclient 923] [  409.472127]  No PIN.
[ rdpclient 923] [  409.472166]  No domain.
[ rdpclient 923] [  409.472204]  No shell.
[ rdpclient 923] [  409.472242]  No directory.
[ rdpclient 923] [  409.472281]  Window: 1920x1080@24.
[ rdpclient 923] [  409.472319]  Second monitor: [1920:0..2943:767].
[ rdpclient 923] [  409.472357]  PFlags 0x0000002F.
[ rdpclient 923] [  409.472396]  Keyboard 00000409:00000000.
[ rdpclient 923] [  409.472446]  My hostname "wtwE840F2A49B0A".
[ rdpclient 923] [  409.472501] TCP: connecting to 192.168.0.115:3389.
[ rdpclient 923] [  409.472562] TCP: connection with 192.168.0.115:3389 established.
[ rdpclient 923] [  409.472619] Turn keepalive on.
[ rdpclient 923] [  409.473218] Free ram after buffers allocation: 3044036 KB.
[ rdpclient 923] [  409.479043] Server supports GFX Pipeline.
[ rdpclient 923] [  409.481177] Process RDP server certificate.
[ rdpclient 923] [  409.481242] RDP5 encryption (X.509).
[ rdpclient 923] [  409.484775] Enable font smoothing and Desktop Composition.
[ rdpclient 923] [  409.555127] GFX codec.
По отдельности мониторы работают, вместе - нет.
Конфиг:
# Конфигурационный файл терминала. Он находится в каталоге
#  Terminals\00.01.23.45.AB.CD\
# Этот файл прочитает терминал с МАК-адресом 00.01.23.45.AB.CD.
# Если терминал не найдет свой конфигурационный файл, он
# предложит провести настройку видеокарты и не станет подключаться
# к терминальному серверу.
# Конфигурационынй файл надо создавать вручную. Под Windows можно
# установить wtware из .exe-дистрибутива и пользоваться графическим
# конфигуратором для создания конфигурационных файлов.
license_e8:40:f2:a4:9b:0a_full = \
60e436471580ae5e148531917c4686ba2437a86bd3ec2a53d235072c14e707a9 \
a356b6fc5d031a9eb9d2d1af59d15431637b867c2ef684e9589b4bb582ae81ee \
725a7ed8de252984b2444d384aed3a93e516e67089f8abde18c847187c04e7c9 \
670ef70ef9f6b70d4f52af3ac4d2c447eea06c296fbe564d8dcbc36182806e41
# Обязательно надо указать, к какому серверу подключаться:
server = 192.168.0.115
# Разрешние экрана. Для LCD-мониторов надо указать разрешение
# матрицы. Любые другие разрешения будут работать хуже или не будут
# работать вообще.
video = gma(F)
bpp = 32
display = 1920x1080, DVI
M2_display = 1024x768, VGA
# Описание остальных параметров смотрите на сайте:
# http://wtware.ru/docs5/config.html
sleep = 30
В данной конфигурации второй монитор периодически моргает (раз в 15-20 сек появляется изображение на мгновение, потом исчезает).
Re: Не могу заставить работать 2 монитора
А где написано, что этот чип умеет два монитора с таким разрешением? У меня получалось только с маленькими разрешениями.
