PXE-E56: No boot file no received
Suleyman
Сообщение Suleyman »
Два тонких клиента - неттопа одной модели непонятно после чего отвалились и не грузятся
на экране следующее
в логах следующее
11-34-41-711| [DHCP] Processing DHCPDISCOVER package...
11-34-41-727| [DHCP] Determine IP for DISCOVER...
11-34-41-727| [DHCP] Sending ARP to check if IP 192.168.60.207 is busy...
11-34-42-015| [DHCP] IP 192.168.60.207 for MAC E0:69:95:20:12:25 determined from terminalDHCP parameters.
11-34-42-015| [DHCP] Stored in catalog IP 192.168.60.207 for MAC E0:69:95:20:12:25
11-34-42-343| [DHCP] Send DHCPOFFER IP: 192.168.60.207.
11-34-42-375| [DHCP] Processing DHCPDISCOVER package...
11-34-42-375| [DHCP] Determine IP for DISCOVER...
11-34-42-390| [DHCP] Sending ARP to check if IP 192.168.60.207 is busy...
11-34-42-406| [DHCP] IP 192.168.60.207 for MAC E0:69:95:20:12:25 determined from terminalDHCP parameters.
11-34-42-422| [DHCP] Stored in catalog IP 192.168.60.207 for MAC E0:69:95:20:12:25
11-34-42-734| [DHCP] Send DHCPOFFER IP: 192.168.60.207.
11-34-42-765| [DHCP] Processing DHCPDISCOVER package...
11-34-42-781| [DHCP] Determine IP for DISCOVER...
11-34-42-796| [DHCP] Sending ARP to check if IP 192.168.60.207 is busy...
11-34-42-812| [DHCP] IP 192.168.60.207 for MAC E0:69:95:20:12:25 determined from terminalDHCP parameters.
11-34-42-812| [DHCP] Stored in catalog IP 192.168.60.207 for MAC E0:69:95:20:12:25
11-34-43-140| [DHCP] Send DHCPOFFER IP: 192.168.60.207.
11-34-43-172| [DHCP] Processing DHCPDISCOVER package...
11-34-43-172| [DHCP] Determine IP for DISCOVER...
11-34-43-187| [DHCP] Sending ARP to check if IP 192.168.60.207 is busy...
11-34-43-203| [DHCP] IP 192.168.60.207 for MAC E0:69:95:20:12:25 determined from terminalDHCP parameters.
11-34-43-218| [DHCP] Stored in catalog IP 192.168.60.207 for MAC E0:69:95:20:12:25
11-34-43-531| [DHCP] Send DHCPOFFER IP: 192.168.60.207.
куда копать?
Re: PXE-E56: No boot file no received
1. В конфигураторе вверху слева кнопка с гаечным ключом. Нажми её. В списке выбери службу DHCP/ Очисти лог, ОДИН раз перегрузи одного подопытного. Выложи лог.
2. Найди и убей второй DHCP. Там же, в утилитах конфигуртаора, есть "Поиск DHCP".
Suleyman
aka писал(а): Вт дек 18, 2018 12:39 pm 2. Найди и убей второй DHCP. Там же, в утилитах конфигуртаора, есть "Поиск DHCP".
Какой то Олень принес роутер и пихнул туда сетевой кабель, осталось найти и убить, а так в общем все норм, спасибо!
