SUCCESS: WTware TFTP server (c) 2003-2007 WTware
ludmila
Сообщение ludmila »
SUCCESS: WTware TFTP server (c) 2003-2007 WTware http://www.wtware.com
INFO : Got RRQ, 36 bytes.
INFO : 00000000: 6c 69 74 65 5c 34 2e 34 2e 35 5c 70 78 65 6c 69
INFO : 00000010: 6e 75 78 2e 30 00 6f 63 74 65 74 00 74 73 69 7a
INFO : 00000020: 65 00 30 00
INFO : 192.168.0.1 requests file "lite\4.4.5\pxelinux.0". Tsize is requested, blksize default.
INFO : Sending OASK (tsize 13340) to 192.168.0.1.
WARNING: Received opcode 5 from 192.168.0.1.
WARNING: 00000000: 00 05 00 00 54 46 54 50 20 41 62 6f 72 74 65 64
WARNING: 00000010: 00
INFO : Got RRQ, 41 bytes.
INFO : 00000010: 6e 75 78 2e 30 00 6f 63 74 65 74 00 62 6c 6b 73
INFO : 00000020: 69 7a 65 00 31 34 35 36 00
INFO : 192.168.0.1 requests file "lite\4.4.5\pxelinux.0". Tsize is not requested, blksize 1456 bytes.
INFO : Sending OASK (blksize 1456) to 192.168.0.1.
INFO : Transfer of file "lite\4.4.5\pxelinux.0" to 192.168.0.1 completed.
INFO : Connection to 192.168.0.1 closed.
INFO : Timeout occured while transfer "lite\4.4.5\pxelinux.0" to 192.168.0.1.
WARNING: Client 192.168.0.1 not responding. Connection closed.
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.0". Tsize is requested, blksize default.
INFO : Sending OASK (tsize 13340) to 192.168.0.2.
WARNING: Received opcode 5 from 192.168.0.2.
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.0". Tsize is not requested, blksize 1456 bytes.
INFO : Sending OASK (blksize 1456) to 192.168.0.2.
INFO : Transfer of file "lite\4.4.5\pxelinux.0" to 192.168.0.2 completed.
INFO : Connection to 192.168.0.2 closed.
INFO : Got RRQ, 72 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 30 31 2d 30 30 2d 38 30
INFO : 00000020: 2d 34 38 2d 34 39 2d 36 66 2d 30 38 00 6f 63 74
INFO : 00000030: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
INFO : 00000040: 7a 65 00 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\01-00-80-48-49-6f-08". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\01-00-80-48-49-6f-08" not found.
INFO : Got RRQ, 60 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 30 30 30 32
INFO : 00000020: 00 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62
INFO : 00000030: 6c 6b 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\C0A80002". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\C0A80002" not found.
INFO : Got RRQ, 59 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 30 30 30 00
INFO : 00000020: 6f 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c
INFO : 00000030: 6b 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\C0A8000". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\C0A8000" not found.
INFO : Got RRQ, 58 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 30 30 00 6f
INFO : 00000020: 63 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b
INFO : 00000030: 73 69 7a 65 00 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\C0A800". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\C0A800" not found.
INFO : Got RRQ, 57 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 30 00 6f 63
INFO : 00000020: 74 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73
INFO : 00000030: 69 7a 65 00 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\C0A80". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\C0A80" not found.
INFO : Got RRQ, 56 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 38 00 6f 63 74
INFO : 00000020: 65 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69
INFO : 00000030: 7a 65 00 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\C0A8". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\C0A8" not found.
INFO : Got RRQ, 55 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 41 00 6f 63 74 65
INFO : 00000020: 74 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a
INFO : 00000030: 65 00 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\C0A". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\C0A" not found.
INFO : Got RRQ, 54 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 30 00 6f 63 74 65 74
INFO : 00000020: 00 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65
INFO : 00000030: 00 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\C0". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\C0" not found.
INFO : Got RRQ, 53 bytes.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 43 00 6f 63 74 65 74 00
INFO : 00000020: 74 73 69 7a 65 00 30 00 62 6c 6b 73 69 7a 65 00
INFO : 00000030: 31 34 34 30 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\C". Tsize is requested, blksize 1440 bytes.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\pxelinux.cfg\C" not found.
INFO : 00000010: 6e 75 78 2e 63 66 67 2f 64 65 66 61 75 6c 74 00
INFO : 192.168.0.2 requests file "lite\4.4.5\pxelinux.cfg\default". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 223, blksize 1440) to 192.168.0.2.
INFO : Transfer of file "lite\4.4.5\pxelinux.cfg\default" to 192.168.0.2 completed.
INFO : 00000000: 6c 69 74 65 5c 34 2e 34 2e 35 5c 77 74 73 68 65
INFO : 00000010: 6c 6c 2f 62 7a 49 6d 61 67 65 00 6f 63 74 65 74
INFO : 192.168.0.2 requests file "lite\4.4.5\wtshell\bzImage". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 798681, blksize 1440) to 192.168.0.2.
WARNING: Incorrect ACK received (expected 330, received 329) from 192.168.0.2.
INFO : Timeout occured while transfer "lite\4.4.5\pxelinux.0" to 192.168.0.2.
INFO : Timeout occured while transfer "lite\4.4.5\wtshell\bzImage" to 192.168.0.2.
WARNING: Incorrect ACK received (expected 427, received 426) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 459, received 458) from 192.168.0.2.
INFO : Transfer of file "lite\4.4.5\wtshell\bzImage" to 192.168.0.2 completed.
INFO : 00000010: 6c 6c 2f 77 74 73 68 65 6c 6c 00 6f 63 74 65 74
INFO : 192.168.0.2 requests file "lite\4.4.5\wtshell\wtshell". Tsize is requested, blksize 1440 bytes.
INFO : Sending OASK (tsize 1191936, blksize 1440) to 192.168.0.2.
WARNING: Incorrect ACK received (expected 70, received 69) from 192.168.0.2.
INFO : Timeout occured while transfer "lite\4.4.5\wtshell\wtshell" to 192.168.0.2.
WARNING: Incorrect ACK received (expected 77, received 76) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 156, received 155) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 224, received 223) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 275, received 274) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 693, received 692) from 192.168.0.2.
INFO : Transfer of file "lite\4.4.5\wtshell\wtshell" to 192.168.0.2 completed.
WARNING: Client 192.168.0.2 not responding. Connection closed.
INFO : Got RRQ, 34 bytes.
INFO : 00000000: 6c 69 74 65 5c 34 2e 34 2e 35 2f 63 6f 6e 66 69
INFO : 00000010: 67 73 2f 6c 69 73 74 2e 77 74 63 00 6f 63 74 65
INFO : 192.168.0.2 requests file "lite\4.4.5\configs\list.wtc". Tsize is not requested, blksize default.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\configs\list.wtc" not found.
INFO : Got RRQ, 47 bytes.
INFO : 00000010: 67 73 2f 30 30 2e 38 30 2e 34 38 2e 34 39 2e 36
INFO : 00000020: 46 2e 30 38 2e 77 74 63 00 6f 63 74 65 74 00
INFO : 192.168.0.2 requests file "lite\4.4.5\configs\00.80.48.49.6F.08.wtc". Tsize is not requested, blksize default.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\configs\00.80.48.49.6F.08.wtc" not found.
INFO : Got RRQ, 37 bytes.
INFO : 00000010: 67 73 2f 64 65 66 61 75 6c 74 2e 77 74 63 00 6f
INFO : 192.168.0.2 requests file "lite\4.4.5\configs\default.wtc". Tsize is not requested, blksize default.
INFO : Requested by 192.168.0.2 file "C:\Program Files (x86)\WTware\TFTPDROOT\lite\4.4.5\configs\default.wtc" not found.
INFO : 00000010: 67 73 2f 77 69 7a 61 72 64 2e 77 74 63 00 6f 63
INFO : 192.168.0.2 requests file "lite\4.4.5\configs\wizard.wtc". Tsize is not requested, blksize default.
INFO : Transfer of file "lite\4.4.5\configs\wizard.wtc" to 192.168.0.2 completed.
INFO : Got RRQ, 35 bytes.
INFO : 00000000: 6c 69 74 65 5c 34 2e 34 2e 35 2f 70 61 63 6b 61
INFO : 00000010: 67 65 73 2f 77 74 6c 73 2e 70 6b 67 00 6f 63 74
INFO : 192.168.0.2 requests file "lite\4.4.5\packages\wtls.pkg". Tsize is not requested, blksize default.
INFO : Timeout occured while transfer "lite\4.4.5\packages\wtls.pkg" to 192.168.0.2.
WARNING: Incorrect ACK received (expected 38, received 37) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 9, received 8) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 174, received 173) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 190, received 189) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 274, received 273) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 18, received 17) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 429, received 428) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 450, received 449) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 611, received 610) from 192.168.0.2.
WARNING: Incorrect ACK received (expected 686, received 685) from 192.168.0.2.
INFO : 00000010: 67 65 73 2f 77 74 6c 78 2e 70 6b 67 00 6f 63 74
INFO : 192.168.0.2 requests file "lite\4.4.5\packages\wtlx.pkg". Tsize is not requested, blksize default.
INFO : Timeout occured while transfer "lite\4.4.5\packages\wtlx.pkg" to 192.168.0.2.
WARNING: Incorrect ACK received (expected 398, received 397) from 192.168.0.2.
И потом ещё пишет Boo failed: press a key
Сеть надо чинить. Скорее всего, проблема именно в физической сети, т.е. пачкордах и розетках.
Для проверки - воткни в ту розетку, в которую воткнут комп 192.168.0.2, машину с виндовсом. И запусти из виндовой командной строки:
ping -l 64000 IPсервера
По исправной сети должны доходить все пакеты.
ludmila
Сообщение ludmila »
С втшелл грузится а пхе нет сервер 2008 стоит + ад
