6.0.4 - wtdhcp, wthttp, wttftp и wtc LOGS ERRORS
3JI0
Сообщение 3JI0 »
Здравствуйте.
Сегодня обновился до версии 6.0.4
вроде всё работает, но во в логах обнаружил следующее:
wtdhcp.log писал(а): [14.05.2020 01:25:45] WTware DHCP server v.6.0.4 (c) 2003-2020 WTware http://www.wtware.com
[14.05.2020 01:25:45] Found interface 192.168.4.250/255.255.255.0 mtu 1500 mac 2C:60:0C:7B:F2:79 adapter Intel(R) I350 Gigabit Network Connection - VLAN : VLAN40.
[14.05.2020 01:25:45] Found interface 192.168.10.250/255.255.255.0 mtu 1500 mac 2C:60:0C:7B:F2:79 adapter Intel(R) I350 Gigabit Network Connection - VLAN : VLAN10.
[14.05.2020 01:25:45] Found interface 192.168.1.250/255.255.255.0 mtu 1500 mac 2C:60:0C:7B:F2:79 adapter Intel(R) I350 Gigabit Network Connection - VLAN : VLAN1.
[14.05.2020 01:25:45] Found interface 192.168.222.1/255.255.255.252 mtu 9000 mac 2C:60:0C:7B:F2:7A adapter Intel(R) I350 Gigabit Network Connection #2.
[14.05.2020 01:25:45] Determined DNS server 192.168.1.254
[14.05.2020 01:25:45] BindIP: 192.168.10.250
[14.05.2020 01:25:45] Creating DHCP iprange...
[14.05.2020 01:25:45] Bind at 192.168.10.250:67.
[14.05.2020 01:25:45] sysiprange: Added IP range: '192.168.10.1-192.168.10.249'.
[14.05.2020 01:25:45] sysiprange: Found reserved ip: *.*.*.*
CUT HERE 97 LINES
[14.05.2020 01:25:45] sysiprange: Result IP ranges:
CUT HERE 45 LINES
[14.05.2020 01:25:45] sysiprange: Found 152 free IPs
[14.05.2020 01:25:45] Reading ignored MACs...
[14.05.2020 01:25:45] DHCPIgnoreMACs: Determining ignore MACs list...
[14.05.2020 01:25:45] DHCPIgnoreMACs: DHCP WILL ignore MAC **:**:**:**:**:**.
CUT HERE 79 LINES
[14.05.2020 07:52:29] DHCPserver.cpp ( 959): -- ERROR -- [20:87:56:6F:E5:B0] Failed to check IP for DHCPREQUEST package. Sending DHCPNAK.
[14.05.2020 07:58:35] DHCPserver.cpp ( 959): -- ERROR -- [00:1B:1B:09:85:D0] Failed to check IP for DHCPREQUEST package. Sending DHCPNAK.
[14.05.2020 08:05:40] Close TCP connection while sending data, errno 2.
wthttp.log писал(а): [14.05.2020 01:25:45] WTware HTTP server v.6.0.4 (c) 2003-2020 WTware http://www.wtware.com
[14.05.2020 01:25:45] Bind at 192.168.10.250:789.
[14.05.2020 07:26:43] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:28:31] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:33:32] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:41:56] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:42:41] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:44:30] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:45:08] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:45:48] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:46:14] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:46:59] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:47:50] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:48:13] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:49:31] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:49:45] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:50:18] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:52:06] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:52:37] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:52:47] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:53:08] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:53:38] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:54:04] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:55:09] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:55:11] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:55:14] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:55:45] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:56:04] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:56:45] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:57:01] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:57:10] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:57:51] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:57:57] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:58:00] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:58:28] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:59:45] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 07:59:53] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:01:40] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:02:25] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:03:19] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:03:46] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:04:28] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:05:09] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:05:29] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:13:18] Close TCP connection while sending data, errno 0.
[14.05.2020 08:13:26] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 08:15:27] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 09:03:17] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 13:53:48] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 17:00:22] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
[14.05.2020 18:05:43] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
wttftp.log писал(а): [14.05.2020 01:25:45] WTware TFTP server v.6.0.4 (c) 2003-2020 WTware http://www.wtware.com
[14.05.2020 01:25:45] Bind at 192.168.10.250:69.
[14.05.2020 06:50:48] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 07:33:28] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 07:41:56] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 07:43:41] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 07:57:04] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 07:58:08] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 08:05:36] Close TCP connection while sending data, errno 0.
[14.05.2020 08:05:58] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 08:42:19] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 13:26:26] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 13:34:13] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[14.05.2020 17:55:59] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
А так же в конфигураторе не видно списка игнорируемых терминалов, хотя он есть и в процессе загрузки dhcp сервиса он применятеся, что видно по логам.
Последний раз редактировалось 3JI0 Пн май 18, 2020 6:20 pm, всего редактировалось 1 раз.
Re: 6.0.4 - wtdhcp, wthttp, wttftp ERROR
1. [14.05.2020 07:52:29] DHCPserver.cpp ( 959): -- ERROR -- [20:87:56:6F:E5:B0] Failed to check IP for DHCPREQUEST package. Sending DHCPNAK.
Если это не втвари, можно забить. Если это втвари, и они не работают, надо разбираться. Начать с удаления их каталогов в C:\ProgramData\WTware\Terminals\
2. [14.05.2020 07:26:43] ..\..\common\serviceMain.cpp ( 201): -- ERROR -- INTERNAL ERROR (0). Please, contact WTware tech support.
Похоже на нашу ошибку. Может так получиться, что длина имени хоста где-то больше 15 символов?
3. Список игнорируемых МАКов лежит в C:\ProgramData\WTware\DHCP\ignore_macs Польователь, который запускает конфигуратор, имеет права на чтение и запись в этот файл?
3JI0
Сообщение 3JI0 »
1. Нет, это виндовс обыкновенный.
2. Имена хостов по дефолту генерируемые втварей (на вложенном скрине видно).
3. Да фаил на месте и он применяется при старте сервиса и у пользователя запускающего конфигуратор права все есть (на вложенном скрине видно).
Так же обратил внимание что в файле wtc.log так же имеются ошибки:
[15.05.2020 06:49:33] ..\..\common\fileio.cpp ( 152): -- ERROR -- Failed to create mailslot "\\.\mailslot\WTDHCPReceiver_5227". Error 183
[15.05.2020 06:49:33] ..\..\common\terminalID.cpp ( 238): -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
[18.05.2020 07:23:04] Unable to open C:\ProgramData\WTware\Terminals\**.**.**.**.**.**. Error 32 (0x20). (на разные директории поругивается не часто, но директории и файлы в ней на месте и права доступа пристуствуют)
[18.05.2020 17:59:56] ..\..\common\fileio.cpp ( 152): -- ERROR -- Failed to create mailslot "\\.\mailslot\WTCInstance". Error 183 (переодически, раз или два в день, проскакивает)
Re: 6.0.4 - wtdhcp, wthttp, wttftp и wtc LOGS ERRORS
Я не вижу ничего страшного. Ругается, да. Отправь мне на aka@pxe.ru архивом всю C:\ProgramData\WTware\Logs Обвешаю все, что ругается, дополнительными проверками и будем копать...
3JI0
Сообщение 3JI0 »
aka писал(а): Пн май 25, 2020 10:07 pm Я не вижу ничего страшного. Ругается, да. Отправь мне на aka@pxe.ru архивом всю C:\ProgramData\WTware\Logs Обвешаю все, что ругается, дополнительными проверками и будем копать...
Готово.
Получил. Напишу, когда будет что попробовать. Наверное, не в ближайшие две недели...
3JI0
Сообщение 3JI0 »
aka писал(а): Чт май 28, 2020 1:15 pm Получил. Напишу, когда будет что попробовать. Наверное, не в ближайшие две недели...
Буду ждать.
