raspberry Pi 4 микрофон
bigmavr
Сообщение bigmavr »
Raspberry Pi 4 Model B Rev 1.2
WTware 6.0.52/RPi
гарнитура jack 3,5
Все замечательно работает, кроме микрофона. В логе следующее
[     alsa2test] [   52.923222] ALSA: control 'HDMI Playback Volume'.
[     alsa2test] [   52.923357] ALSA: control 'HDMI Playback Switch'.
[     alsa2test] [   52.923467] ALSA: use device hw:0:0.
[     alsa2test] [   52.923686] ALSA: Hardware rate 44100Hz.
[     alsa2test] [   52.924024] ALSA: chunk size 512 frames, 1024 bytes, 11 msec.
[     alsa2test] [   52.924140] ALSA: buffer size 131072 bytes, 1486 miliseconds.
[     alsa2test] [   54.666975] Card 'Headphones'/'bcm2835 Headphones'.
[     alsa2test] [   54.667138] Mixer name: 'Broadcom Mixer'.
[     alsa2test] [   54.667273] Components: ''.
[     alsa2test] [   54.667418] Controls: 2.
[     alsa2test] [   54.667571] ALSA: control 'Headphone Playback Volume'.
[     alsa2test] [   54.667754] ALSA: control 'Headphone Playback Switch'.
[     alsa2test] [   54.667972] ALSA: use device hw:1:0.
[     alsa2test] [   54.668894] ALSA: Hardware rate 44100Hz.
[     alsa2test] [   54.669367] ALSA: chunk size 512 frames, 1024 bytes, 11 msec.
[     alsa2test] [   54.669518] ALSA: buffer size 131072 bytes, 1486 miliseconds.
[ rdpclient 891] [   63.549629] [SOUND] AAC compressed sound 44100 frames per second.
[ rdpclient 891] [   63.549811] [ALSA] Start speaker plugin.
[ rdpclient 891] [   63.692873] [ALSA PLAY] Use device hw:1,0.
[ rdpclient 891] [   63.697706] [ALSA PLAY] Hardware rate 44100Hz.
[ rdpclient 891] [   63.698041] [ALSA PLAY] Chunk size 444 frames, 1776 bytes, 10 msec.
[ rdpclient 891] [   90.069054] Redirect microphone.
[ rdpclient 891] [   90.070115] [ALSA] Start microphone plugin.
[ rdpclient 891] [   90.070239] [ALSA MIC] Use device hw:1,0.
[ rdpclient 891] [   90.070514] [ALSA ERROR] pcm_hw.c:1711:(snd_pcm_hw_open) open '/dev/snd/pcmC1D0c' failed (-2): No such file or directory
[ rdpclient 891] [   90.070576] [ALSA MIC ERROR] Audio open error: No such file or directory
[ rdpclient 891] [   90.070623] [ALSA MIC ERROR] Unable to start recording.
[ rdpclient 891] [   97.982708] Redirect microphone.
[ rdpclient 891] [  103.433324] Redirect microphone.
[ rdpclient 891] [  108.102213] Redirect microphone.
[ rdpclient 891] [  113.288455] Redirect microphone.
можно ли как то поправить эту ошибку.
Спасибо.
full.log
(38.2 КБ) 617 скачиваний
Bambor
Re: raspberry Pi 4 микрофон
Сообщение Bambor »
Если посмотреть спецификацию малины, то станет понятно что в ней нет микрофона.
bigmavr
Сообщение bigmavr »
Спасибо. Уже нашел ответ на их сайте.
