Поддержка rtp протокола в VLC плеере
GBUZ_KKOD
Сообщение GBUZ_KKOD »
Подскажите пожалуйста есть ли поддержка rtp протокола в VLC плеере. Если есть, как правильно указать подключение к мультикаст группе по этому протоколу, так как при попытки воспроизвести видео по rtp (vlc_cmdline=rtp://@224.0.0.2:1234) на мониторе пишет "VLC остановлен. Смотрите логи.", при этом в vlc на PC (Windows) по этому URL (rtp://@224.0.0.2:1234) видео воспроизводится.
WTware 6.0.60
Raspberry Pi 3B+
VLC в WTware
VLC на PC
Лог
[            gm] [   56.308890] modprobe snd-bcm2835.
[        KERNEL] [   56.327185] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[        KERNEL] [   56.331048] bcm2835_audio bcm2835_audio: card created with 4 channels
[        KERNEL] [   56.334351] bcm2835_audio bcm2835_audio: card created with 4 channels
[            gm] [   56.333668] modprobe snd-usb-audio.
[        KERNEL] [   56.346449] mc: Linux media interface: v0.10
[        KERNEL] [   56.369392] usbcore: registered new interface driver snd-usb-audio
|   0: [ 0]   : control
|  16: [ 0- 0]: digital audio playback
|  32: [ 1]   : control
|  33:        : timer
|  48: [ 1- 0]: digital audio playback
[            gm] [   57.369806] /dev/snd//controlC1 character device.
[          pfac] [   57.369921] Run /sbin/snd_start 100 100 100.
[            gm] [   57.369973] /dev/snd//pcmC1D0p character device.
[          pfac] [   57.370121] Ok, PID 756.
[            gm] [   57.370194] /dev/snd//controlC0 character device.
[            gm] [   57.370315] /dev/snd//pcmC0D0p character device.
[            gm] [   57.370399] /dev/snd//timer character device.
[            gm] [   57.370479] Run '/sbin/snd_start 100 100 100', log '', env '', pid ''.
[     snd_start] [   57.377069] Onboard sound, level 100: bcm2835 HDMI 1.
[     snd_start] [   57.381944] Card 'b1'/'bcm2835 HDMI 1'.
[     snd_start] [   57.382049] Mixer name: 'Broadcom Mixer'.
[     snd_start] [   57.382132] Components: ''.
[     snd_start] [   57.382214] HDMI Playback Volume: integer -10239..400 step 0, Volume 100% -> 400.
[     snd_start] [   57.382297] HDMI Playback Switch: boolean, turn ON.
[     snd_start] [   57.382379] Onboard sound, level 100: bcm2835 Headphones.
[     snd_start] [   57.382460] Card 'Headphones'/'bcm2835 Headphones'.
[     snd_start] [   57.382542] Mixer name: 'Broadcom Mixer'.
[     snd_start] [   57.382623] Components: ''.
[     snd_start] [   57.382703] Headphone Playback Volume: integer -10239..400 step 0, Volume 100% -> 400.
[     snd_start] [   57.382785] Headphone Playback Switch: boolean, turn ON.
[          pfac] [   57.384172] Process pid 756 terminated, status 00000000.
[        KERNEL] [   57.624617] zram0: detected capacity change from 0 to 956911616
[            gm] [   57.709952] Run '/usr/bin/vlc -I dummy --play-and-exit --fullscreen --video-title WTware_M0S0 rtp://@224.0.0.2:1234 --alsa-audio-device plughw:0', log '/tmp/Xapp00.out', env 'DISPLAY=:0.0 LANG=ru_RU.utf8 LANGUAGE=ru_RU', pid '/tmp/Xapp00.pidpipe'.
[        KERNEL] [   57.701688] Adding 934480k swap on /dev/zram0.  Priority:-2 extents:1 across:934480k SSFS
[          pfac] [   57.710415] Run /usr/bin/vlc -I dummy --play-and-exit --fullscreen --video-title WTware_M0S0 rtp://@224.0.0.2:1234 --alsa-audio-device plughw:0.
[          pfac] [   57.710707] Ok, PID 758.
[X00] close kotopipe (n = 0, errno 0).
[          pfac] [   57.711481] Process pid 758 terminated, status 00007f00.
[            gm] [   58.710575] Success, pid 758.
[            gm] [   58.710799] Everyone can control terminal by VNC.
[            gm] [   58.711022] [VNC] Listener at port 5900.
[            gm] [   58.711158] Everyone can control terminal by WTRC.
[            gm] [   58.711328] [WTRC] Remote control with Setup/HTTPS password.
[            gm] [   58.722999] [WTRC] Listener at TCP port 789.
Re: Поддержка rtp протокола в VLC плеере
В втвари на Raspberry сейчас нету VLC.
Потому что сначала у VLC не было акселераации на Raspberry и все торозило, а потом никто не просил.
На штатном Raspberry OS на той же малине то же видео по rtp поедет?
GBUZ_KKOD
aka писал(а): Ср фев 16, 2022 3:12 pm В втвари на Raspberry сейчас нету VLC.
не проверяли, так как полностью перешли на WTware.
kike
Сообщение kike »
Доброе время суток, а ожидать реализации на WTware на Raspberry Pi 4 ? Есть потребность на одном мониторе rdp, на другом видео поток
Я выше уже спрашивал: на шаттной raspberry os тот же видеопоток в том же разершении через vlc хорошо работает?
kike
Сообщение kike »
aka писал(а): Вс сен 17, 2023 9:04 pm Я выше уже спрашивал: на шаттной raspberry os тот же видеопоток в том же разершении через vlc хорошо работает?
модель Raspberry PI 4b
OS Raspberry с иксами
поток rtsp
Разрешение видео.: 2688x1520
полет нормальный , 2 часа теста
