Kyocera FS1120D и win2016
gr1mm3r
Сообщение gr1mm3r »
Не могу разобраться с проблемой подключения принтера Kyocera FS-1120D на 2016
Делал все по мануалу:
Поставил на локальный комп, пробросил на тестовый РДП - печатает.
Поставил на сервер - печатает
Поставил на терминал - Обнаружился, но не печатает
Пробрасывал как порт
usb=1-3, 1-2, 1-4
printer=usb
Драйвера стоят последние с сайта.
В логах только эти записи по принтеру.
 KERNEL] [    2.108424] usb 1-3: new high-speed USB device number 3 using xhci_hcd
[        KERNEL] [    2.258554] usb 1-3: New USB device found, idVendor=0482, idProduct=0407, bcdDevice= 0.00
[        KERNEL] [    2.258570] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[        KERNEL] [    2.258583] usb 1-3: Product: Kyocera FS-1120D
[        KERNEL] [    2.258595] usb 1-3: Manufacturer: Kyocera
[        KERNEL] [    2.258604] usb 1-3: SerialNumber: L4W2702091
[        initrd] [    2.270785] Load Ethernet drivers.
[ rdpclient 933] [   37.404552] GFX decoder thread.
[ rdpclient 933] [   37.408360] Graphics output buffer 960x768, 1 monitors.
[ rdpclient 933] [   37.408657] Monitor 0: 0.0-959.767 primary.
[ rdpclient 933] [   38.116263] Run 2 tile threads.
[ rdpclient 933] [   38.189952] errorInfo 0x00000000.
[ rdpclient 933] [   38.632145] SessionId 0x00000001: domain\user.
[        KERNEL] [   38.688577] usblp0: removed
[     printer 0] [  272.680811] [PRINT ERROR] Failed to open printer device /dev/usb/lp0.
[     printer 0] [  272.685741] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.685965] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.686115] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.686260] [PRINT ERROR] Failed to write 6084 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.687001] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.687220] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.687369] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.687597] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.687749] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.687892] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.688034] [PRINT ERROR] Failed to write 8192 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.688177] [PRINT ERROR] Failed to write 3335 bytes to printer: write() return -1, errno 9.
[     printer 0] [  272.688322] Printer device not found. Waiting...
При этом когда добавил disk=usb - флешка работает на ура
Re: Kyocera FS1120D и win2016
для развенчания некоторых моментов моей криворукости принтер HP завелся нормально.
Сейчас при очередной перезагрузке терминала я заметил в логах только что вошедшего пользователя строчку
[ KERNEL] [ 161.603428] usblp0: removed
мыслей нет совсем.
Надо прочитать внимательно и выполнить все так, как написано:
http://wtware.ru/logs.html
Особенно внимательно отнестись к пункту 2: "удалить всё кроме необходимых строк". Вот такой конфиг:
usb=1-3, 1-2, 1-4
printer=usb
Никак не может существовать. Это два разных метода перенаправления, и они скорее конфликтовать. Одну из двух строк необходимо удалить.
gr1mm3r
Сообщение gr1mm3r »
Спасибо.
Действительно продолбал момент указания проброса USB. Все заработало.
Вернуться в «Принтеры»
