Доброго дня!
Есть терминальный сервер с порядка 100 клиентами, и после перезагрузки его некоторые тонкие не хотят подключаться через wtware, хотя с если пробовать подключиться с компьютера через удаленный рабочий стол, все прекрасно входит. Через час-два эти клиенты начинают работать. Не могу победить проблему
[ gm] [ 4140.396999] Run '/sbin/resolver 0x562890863000 dns [192.168.90.45]', log '', env '', pid ''.
[ pfac] [ 4140.397320] Run /sbin/resolver 0x562890863000 dns [192.168.90.45].
[ pfac] [ 4140.397368] Ok, PID 634.
[ pfac] [ 4140.398857] Process pid 634 terminated, status 00000000.
[ gm] [ 4140.400460] 192.168.90.45 => 192.168.90.45.
[ gm] [ 4140.404842] Free ram before fork terminal client /sbin/rdpclient (session 34): 3831464 Kb.
[ gm] [ 4140.404939] Run '/sbin/rdpclient 34', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 4140.405230] Run /sbin/rdpclient 34.
[ pfac] [ 4140.405276] Ok, PID 635.
[ rdpclient 635] [ 4140.410720] RDP Terminal Client, WTware 6.0.72/UEFI, pipe 34, pid 635.
[ rdpclient 635] [ 4140.410922] Use /usr/lib/ui32.so.
[ rdpclient 635] [ 4140.411506] Redirect sound.
[ rdpclient 635] [ 4140.413017] Make RDP session with 192.168.90.45, port 3389.
[ rdpclient 635] [ 4140.413091] Username: "101".
[ rdpclient 635] [ 4140.413149] Password: present.
[ rdpclient 635] [ 4140.413205] No PIN.
[ rdpclient 635] [ 4140.413263] Domain: "crb.local".
[ rdpclient 635] [ 4140.413319] No shell.
[ rdpclient 635] [ 4140.413376] No directory.
[ rdpclient 635] [ 4140.413434] Window: 1856x1080@32.
[ rdpclient 635] [ 4140.413493] PFlags 0x0000002E.
[ rdpclient 635] [ 4140.413553] Keyboard 00000409:00000000.
[ rdpclient 635] [ 4140.413610] My hostname "wtw241C04136422".
[ rdpclient 635] [ 4140.413670] TCP: connecting to 192.168.90.45:3389.
[ rdpclient 635] [ 4170.443958] select () timed out.
[ rdpclient 635] [ 4170.444009] rdpclient-tcp.cpp ( 278): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 635] [ 4170.444048] Сервер 192.168.90.45, порт 3389: отказано в подключении.
Убедитесь, что на этом сервере работает служба терминалов
и попробуйте подключиться к ней стандартным клиентом
службы терминалов mstsc.exe.
[ gm] [ 4170.444610] Session is over. Final message: Сервер 192.168.90.45, порт 3389: отказано в подключении.
[ pfac] [ 4170.444688] Process pid 635 terminated, status 00000009.
Send WTCU discover to 192.168.90.121.
Вот кусочек из лога терминала
Не загружается терминал
taburetka1985
Re: Не загружается терминал
Я тем более не смогу победить. С нашей стороны здесь из настроек только правильно указать настройки сети терминала: IP и маску, если нужно - шлюз и MTU. Дальше делается connect(), и если он через тридцать секунд не коннектится, то проблема решается не у нас.
В логе терминал не может открыть TCP соединение. До RDP ещё далеко, не работает TCP/IP. Или на сервере сломали IP стек (его кроме админских рук ломает левый антивирус с фаирволом), или если между терминалом и сервером есть маршрутизаторы - ещё они под подозрением.
Поставить рядом (т.е. воткнуть в соседний порт свича, если сервер виртуальный - на том же гипервизоре) новый сервер, убедиться, что на неполоманом сервере прекрасно входят действительно все, и переставлять основной сервер. Впредь тщательнее следить за руками, лезущими в настройки без понимания.
