Отключить всплывающие программы-мониторы принтеров
Submitted by Rick Keifer (not verified) on Fri, 2007/08/24 - 10:03am.
Hey fellas. i have run into this before specifically in Terminal server envrionments but also in stand alone server.
if you open regedit and go to HKLM/CurrentControlSet/control/print/environments/windows nt x86/drivers/version-3/ (this if for a windows 2003 server)
under this hive are listed all the printers shared or not on the server. in each printer you will find a key called monitor. delete the contents of any monitor key. make sure not to delete the monitor key itself just anything in it.
You should always do this on your stand alone servers and it is imperative you do it on a terminal server. hope this helps. much better then restarting the spooler everytime :)
alper
Re: Отключить всплывающие программы-мониторы принтеров
Сообщение alper »
сделал так как описано, в результате процесс спулера стал отнимать все свободное процессорное время.
не рекомендую.
Вернуться в «Tips and tricks»
