wtware и vnc
hell
wtware и vnc
Сообщение hell »
решил законектицо терминалом к дебиану
получаю ждите...
вот лог
[SYSLOG] <14>Dec 28 10:55:34 syslog: usbipd: info: listening on 0.0.0.0:3240
[gm] fstream.cpp ( 548), connect: -- ERROR -- Conection with 192.168.1.123:780 failed, errno 111.
[gm] ERROR: connection to WTware SUBIP Initiator service at 192.168.1.123 port 780 failed.
[pfac] Got command line /sbin/resolver 08994c58 dns [192.168.3.7].
[pfac] Ok, PID 575.
[pfac] Process pid 575 terminated, status 00000000.
[gm] 192.168.3.7 => 192.168.3.7. // это айпи дебиана
[gm] Free ram before fork terminal client /sbin/vncclient (session 1): 754300 Kb.
[pfac] Got command line /sbin/vncclient 1.
[pfac] Ok, PID 576.
[vncclient 576] VNC Client, WTware v.5.0.6, pipe 1, pid 576.
[vncclient 576] Make VNC session with 192.168.3.7:5900.
[vncclient 576] TCP: connecting to 192.168.3.7:5900.
[vncclient 576] TCP: connection with 192.168.3.7:5900 established.
[vncclient 576] Server VNC version 7.
[vncclient 576] VNC screen 800x600, bpp 32 depth 24, low endian true color.
[vncclient 576] Server name "maxi@debian83".
[vncclient 576] Resolution 800x600.
[vncclient 576] 32 bits per pixel.
[KERNEL] hub 2-0:1.0: state 7 ports 6 chg 0000 evt 0002
[KERNEL] ehci_hcd 0000:00:06.1: GetStatus port:1 status 001002 0 ACK POWER sig=se0 CSC
[KERNEL] hub 2-0:1.0: port 1, status 0100, change 0001, 12 Mb/s
[KERNEL] usb 2-1: USB disconnect, device number 2
[KERNEL] usb 2-1.2: USB disconnect, device number 5
[KERNEL] usb 2-1.2: unregistering device
[KERNEL] usb 2-1.2: unregistering interface 2-1.2:1.0
[KERNEL] usb 2-1.2: unlink qh8-0601/eeae5940 start 3 [1/2 us]
[KERNEL] ehci_hcd 0000:00:06.1: shutdown urb ee9da5c0 ep1in-intr
[KERNEL] ehci_hcd 0000:00:06.1: detected XactErr len 0/4 retry 1
[KERNEL] usb 2-1.2: unregistering interface 2-1.2:1.1
[KERNEL] usb 2-1.2: unlink qh8-0601/eeae5800 start 4 [1/2 us]
[KERNEL] ehci_hcd 0000:00:06.1: shutdown urb ee9da1c0 ep2in-intr
[KERNEL] usb 2-1.2: usb_disable_device nuking all URBs
[KERNEL] ehci_hcd 0000:00:06.1: detected XactErr len 0/8 retry 1
[KERNEL] usb 2-1.3: USB disconnect, device number 4
[KERNEL] usb 2-1.3: unregistering device
[KERNEL] usb 2-1.3: unregistering interface 2-1.3:1.0
[KERNEL] usb 2-1.3: unlink qh16-0601/eea1f580 start 2 [1/2 us]
[KERNEL] ehci_hcd 0000:00:06.1: shutdown urb eea2f240 ep1in-intr
[KERNEL] usb 2-1.3: unregistering interface 2-1.3:1.1
[KERNEL] usb 2-1.3: usb_disable_device nuking all URBs
[KERNEL] usb 2-1: unregistering device
[KERNEL] usb 2-1: unregistering interface 2-1:1.0
[KERNEL] usb 2-1: unlink qh256-0001/eea1fc00 start 1 [1/0 us]
[KERNEL] ehci_hcd 0000:00:06.1: shutdown urb eea2f3c0 ep1in-intr
[KERNEL] usb 2-1: usb_disable_device nuking all URBs
[KERNEL] hub 2-0:1.0: debounce: port 1: total 100ms stable 100ms status 0x100
Re: wtware и vnc
Словами расскажи. Как ты хочешь законнектиться и что получить в результате.
hell
Re: wtware и vnc
Сообщение hell »
aka писал(а):Словами расскажи. Как ты хочешь законнектиться и что получить в результате.
хочу чтоб втваре приконектилась к серверу с дебианом по vnc. типа виндового рдп сеанса
Re: wtware и vnc
В логе ошибок нет. На экране что нарисовано?
hell
Re: wtware и vnc
Сообщение hell »
aka писал(а):В логе ошибок нет. На экране что нарисовано?
на черном экране, пожалуста ждите .....
Re: wtware и vnc
1. У тебя в логе:
"[vncclient 576] Server VNC version 7."
Это VNC сервер на дебиане говорит, что у него версия 7. У меня дебиан пишет "version 8". Лучше обнови, там изменения в протоколе были.
2. Наши ошибки есть, исправил. С линуксом напрямую по vnc работать получается намного лучше, чем с тем же линуксом, но подключаясь к vmware. И лучше чем с tightvnc на виндовсе. Но все равно значительно тормознутее, чем с RDP. И с русскими буквами вопрос скорее всего не решится.
Вот здесь исправленная версия, у меня оно к дебиану подключается. Попробуй, поедет?
http://pxe.ru/files/testing/201201070414.zip
Глубина цвета терминала, параметр bpp= в конфиге втвари, должен соответствовать параметру $depth= в файле /usr/bin/vnc4server на линуксе. Если в втвари bpp=16, то $depth=16. Если в втвари bpp=32, то $depth=24. После изменения $depth VNC-сервер надо перезапустить.
hell
Re: wtware и vnc
Сообщение hell »
С праздниками )))
новая версия дает ошибку при загрузке , еще не разбирался, но заработала старая версия )))
собственно хочу попробовать прокинуть USB , на дебиан поставил ipusb
вот кусок лога.... непойму толи порт не разрешен и где толи что... мозг взорван
[gm] +- Errorlevel: 0, output:
[KERNEL] usbcore: registered new interface driver usbip-host
[KERNEL] usbip_host: USB/IP Host Driver v1.0.0
[gm] +------------------------
[gm] +--- Executing "/sbin/usbipd -D"
[gm] WTware USBIP Initiator Server 192.168.1.123 => 192.168.1.123.
[gm] Redirect "2-3".
[gm] /sys/bus/usb/devices/2-3:1.0/driver 046d:0817 use driver none.
[gm] /sys/bus/usb/devices/2-3:1.1/driver 046d:0817 use driver none.
[KERNEL] usbip-host 2-3:1.0: usb_probe_interface
[KERNEL] usbip-host 2-3:1.0: usb_probe_interface - got id
[KERNEL] usbip-host 2-3:1.0: usbip-host: register new device (bus 2 dev 3 ifn 0)
[KERNEL] usbip-host 2-3:1.1: usb_probe_interface
[KERNEL] usbip-host 2-3:1.1: usb_probe_interface - got id
[KERNEL] usbip-host 2-3:1.1: usbip-host: register new interface (bus 2 dev 3 ifn 1)
[SYSLOG] <14>Jan 10 11:00:06 syslog: usbipd: info: starting usbipd (usbip-utils 1.0.6)
[SYSLOG] <14>Jan 10 11:00:06 syslog: usbipd: info: listening on 0.0.0.0:3240
[pfac] Got command line /sbin/resolver 0873bc58 dns [192.168.3.7].
[pfac] Ok, PID 572.
[pfac] Process pid 572 terminated, status 00000000.
[gm] Free ram before fork terminal client /sbin/vncclient (session 1): 754416 Kb.
[pfac] Ok, PID 573.
Re: wtware и vnc
В самом первом логе точно такая же ошибка. Потому что наша служба wtusbip, которая автоматизирует подключение устройства, - она только для виндовса. Для проброса устройства на линукс надо как-то иначе автоматизировать подключение. Нельзя писать shared_usb=server:IP линукса, потому что на IP линукса не ответят.
Просто shared_usb=on (или =USBID), и на линуксе руками пускать usbip для проброса.
