Размер шрифтов в 2008 сервере
By default, Windows Server 2008, used in a terminal server \ Citrix environment, does not allow standard users to change their font sizes. There is an option available to change font sizes, but it is locked down to administrators only. This is a Windows Server 2008 feature. If you try and use the standard Windows option to change font sizes, you will be prompted to provide an administrator login name and password. Unfortunately, with Windows Server 2008 the font size-changing feature is a system-wide administrative feature, rather than an individual user feature as it was in Windows Server 2003 – impacting terminal server \ Citrix environments.
To compensate for this loss of functionality for users, a tool has been produced that users can use to change font sizes! – called ‘RDFontSize’.
RDFontSize.zip
(948.47 КБ) 1521 скачивание
Important: You need to logoff and back on for your new font sizes to completely take effect.
There are some limitations with the tool:
It doesn’t change applications – only Windows fonts
It doesn’t change ‘Favorites’ & ‘Recent Items’ with Vista theme (fine with Classic)
If you switch from Vista to Classic or vise versa, the font settings get reset.
snippyy
Re: Размер шрифтов в 2008 сервере
Сообщение snippyy »
Спасибо, хорошая утилита.
Жаль, что позволяет менять размер только системных шрифтов.
Шрифт в приложении остается без изменений.
Приходится для каждого приложения менять шрифт средствами самого приложения.
Вот, например, для Ауглюка нашел:
http://www.geckostech.co.uk/?p=168
А вот что делать, если приложение не позволяет размер шрифта изменить?
Вернуться в «Tips and tricks»
