Metrologic MS-9540 (2400,e,7,2)
rassik
Терминал IskanderLabs и Metrologic MS9540 USB не работает
Сообщение rassik »
Здравствуйте.
Не могу подключить к терминалу IskanderLabs сканер штрихкодов Metrologic MS9540 USB.
Лог
WTCENTER: Close connection.
+--- FILE "/tmp/all.log" -----------------------
| WTware PRO 4.4.16 supervisor.
| KERNEL: Linux version 2.4.36 (root@compiler) (gcc version 3.4.6) #72 Tue Jul 22 13:12:44 MDT 2008
| KERNEL: BIOS-provided physical RAM map:
| KERNEL: BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
| KERNEL: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
| KERNEL: BIOS-e820: 0000000000100000 - 0000000003ef0000 (usable)
| KERNEL: BIOS-e820: 0000000003ef0000 - 0000000003ef3000 (ACPI NVS)
| KERNEL: BIOS-e820: 0000000003ef3000 - 0000000003f00000 (ACPI data)
| KERNEL: BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
| KERNEL: 62MB LOWMEM available.
| KERNEL: On node 0 totalpages: 16112
| KERNEL: zone(0): 4096 pages.
| KERNEL: zone(1): 12016 pages.
| KERNEL: zone(2): 0 pages.
| KERNEL: ACPI: RSDP (v000 IntelR ) @ 0x000f69b0
| KERNEL: ACPI: RSDT (v001 IntelR AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x03ef3000
| KERNEL: ACPI: FADT (v001 IntelR AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x03ef3040
| KERNEL: ACPI: DSDT (v001 INTELR AWRDACPI 0x00001000 MSFT 0x0100000e) @ 0x00000000
| KERNEL: Kernel command line: root=/dev/ram/0 ramdisk_blocksize=4096 ramdisk_size=8192 quiet initrd=wtshell/wtshell BOOT_IMAGE=wtshell/bzImage
| KERNEL: No local APIC present or hardware disabled
| KERNEL: Initializing CPU#0
| KERNEL: Detected 567.962 MHz processor.
| KERNEL: Console: colour VGA+ 80x25
| KERNEL: Calibrating delay loop... 1133.77 BogoMIPS
| KERNEL: Memory: 59792k/64448k available (1038k kernel code, 4272k reserved, 520k data, 108k init, 0k highmem)
| KERNEL: Dentry cache hash table entries: 8192 (order: 4, 65536 bytes)
| KERNEL: Inode cache hash table entries: 4096 (order: 3, 32768 bytes)
| KERNEL: Mount cache hash table entries: 512 (order: 0, 4096 bytes)
| KERNEL: Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
| KERNEL: Page-cache hash table entries: 16384 (order: 4, 65536 bytes)
| KERNEL: CPU: L1 I cache: 16K, L1 D cache: 16K
| KERNEL: CPU: L2 cache: 128K
| KERNEL: CPU: After generic, caps: 0383f9ff 00000000 00000000 00000000
| KERNEL: CPU: Common caps: 0383f9ff 00000000 00000000 00000000
| KERNEL: CPU: Intel Celeron (Coppermine) stepping 03
| KERNEL: Enabling fast FPU save and restore... done.
| KERNEL: Enabling unmasked SIMD FPU exception support... done.
| KERNEL: Checking 'hlt' instruction... OK.
| KERNEL: ACPI: IRQ9 SCI: Edge set to Level Trigger.
| KERNEL: POSIX conformance testing by UNIFIX
| KERNEL: mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
| KERNEL: mtrr: detected mtrr type: Intel
| KERNEL: ACPI: Subsystem revision 20040326
| KERNEL: PCI: PCI BIOS revision 2.10 entry at 0xfb2b0, last bus=1
| KERNEL: PCI: Using configuration type 1
| KERNEL: ACPI: Interpreter enabled
| KERNEL: ACPI: Using PIC for interrupt routing
| KERNEL: ACPI: System [ACPI] (supports S0 S1 S4 S5)
| KERNEL: ACPI: PCI Root Bridge [PCI0] (00:00)
| KERNEL: PCI: Probing PCI hardware (bus 00)
| KERNEL: Transparent bridge - Intel Corporation 82801AA PCI Bridge
| KERNEL: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
| KERNEL: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 11 *12 14 15)
| KERNEL: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
| KERNEL: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
| KERNEL: ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 9 10 11 12 14 15)
| KERNEL: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0
| KERNEL: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0
| KERNEL: ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0
| KERNEL: ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0
| KERNEL: ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 12
| KERNEL: ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 3
| KERNEL: ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 5
| KERNEL: ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
| KERNEL: PCI: Using ACPI for IRQ routing
| KERNEL: isapnp: Scanning for PnP cards...
| KERNEL: isapnp: No Plug & Play device found
| KERNEL: Linux NET4.0 for Linux 2.4
| KERNEL: Based upon Swansea University Computer Society NET3.039
| KERNEL: Initializing RT netlink socket
| KERNEL: Starting kswapd
| KERNEL: devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
| KERNEL: devfs: boot_options: 0x1
| KERNEL: ACPI: Power Button (FF) [PWRF]
| KERNEL: ACPI: Processor [CPU0] (supports C1, 2 throttling states)
| KERNEL: Detected PS/2 Mouse Port.
| KERNEL: RAMDISK driver initialized: 16 RAM disks of 8192K size 4096 blocksize
| KERNEL: Initializing Cryptographic API
| KERNEL: NET4: Linux TCP/IP 1.0 for NET4.0
| KERNEL: IP Protocols: ICMP, UDP, TCP
| KERNEL: IP: routing cache hash table of 512 buckets, 4Kbytes
| KERNEL: TCP: Hash tables configured (established 4096 bind 8192)
| KERNEL: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
| KERNEL: RAMDISK: cramfs filesystem found at block 0
| KERNEL: RAMDISK: Loading 1664 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\done.
| KERNEL: Freeing initrd memory: 1664k freed
| KERNEL: VFS: Mounted root (cramfs filesystem) readonly.
| KERNEL: Mounted devfs on /dev
| KERNEL: Freeing unused kernel memory: 108k freed
| pfac: Ok, PID 10.
| initrd: WTware PRO shell, v.4.4.16
| initrd: Kernel command line: root=/dev/ram/0 ramdisk_blocksize=4096 ramdisk_size=8192 quiet initrd=wtshell/wtshell BOOT_IMAGE=wtshell/bzImage
| initrd: Ethernet boot.
| initrd: Kernel: 2.4.36, modules in /lib/modules/2.4.36.
| initrd: PCIID: 8086:7120 sub 8086:7120, class 0x0600.
| initrd: PCIID: 8086:7121 sub 8086:7121, class 0x0300.
| initrd: PCIID: 8086:2418 sub 0000:0000, class 0x0604.
| initrd: PCIID: 8086:2410 sub 0000:0000, class 0x0601.
| initrd: PCIID: 8086:2411 sub 8086:2411, class 0x0101.
| initrd: PCIID: 8086:2412 sub 8086:2412, class 0x0c03.
| initrd: PCIID: 8086:2413 sub 8086:2413, class 0x0c05.
| initrd: PCIID: 8086:2415 sub 414c:4720, class 0x0401.
| initrd: PCIID: 10ec:8139 sub 10ec:8139, class 0x0200.
| initrd: PCIID, network: 10ec:8139.
| initrd: PCIID, VGA: 8086:7121.
| initrd: PCIID, sound: 8086:2415.
| +--- FILE "/proc/pci" -----------------------
| | PCI devices found:
| | Bus 0, device 0, function 0, WTCODE 0600 8086 7120 8086 7120
| | Host bridge: Intel Corporation 82810 GMCH (Graphics Memory Controller Hub) (rev 3).
| | Bus 0, device 1, function 0, WTCODE 0300 8086 7121 8086 7121
| | VGA compatible controller: Intel Corporation 82810 (CGC) Chipset Graphics Controller (rev 3).
| | IRQ 12.
| | Prefetchable 32 bit memory at 0xe0000000 [0xe3ffffff].
| | Non-prefetchable 32 bit memory at 0xe4100000 [0xe417ffff].
| | Bus 0, device 30, function 0, WTCODE 0604 8086 2418 0000 0000
| | PCI bridge: Intel Corporation 82801AA PCI Bridge (rev 2).
| | Master Capable. No bursts. Min Gnt=6.
| | Bus 0, device 31, function 0, WTCODE 0601 8086 2410 0000 0000
| | ISA bridge: Intel Corporation 82801AA ISA Bridge (LPC) (rev 2).
| | Bus 0, device 31, function 1, WTCODE 0101 8086 2411 8086 2411
| | IDE interface: Intel Corporation 82801AA IDE Controller (rev 2).
| | I/O at 0xf000 [0xf00f].
| | Bus 0, device 31, function 2, WTCODE 0c03 8086 2412 8086 2412
| | USB Controller: Intel Corporation 82801AA USB Controller (rev 2).
| | IRQ 3.
| | I/O at 0xd000 [0xd01f].
| | Bus 0, device 31, function 3, WTCODE 0c05 8086 2413 8086 2413
| | SMBus: Intel Corporation 82801AA SMBus Controller (rev 2).
| | IRQ 5.
| | I/O at 0x5000 [0x500f].
| | Bus 0, device 31, function 5, WTCODE 0401 8086 2415 414c 4720
| | Multimedia audio controller: Intel Corporation 82801AA AC'97 Audio Controller (rev 2).
| | IRQ 5.
| | I/O at 0xd800 [0xd8ff].
| | I/O at 0xdc00 [0xdc3f].
| | Bus 1, device 10, function 0, WTCODE 0200 10ec 8139 10ec 8139
| | Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 16).
| | IRQ 11.
| | Master Capable. Latency=32. Min Gnt=32.Max Lat=64.
| | I/O at 0xc000 [0xc0ff].
| | Non-prefetchable 32 bit memory at 0xe4000000 [0xe40000ff].
| initrd: RAM: 61564Kb total, 51752Kb free.
| initrd: Force USB hub driver.
| initrd: Loading usb bus driver.
| initrd: +--- Executing "/sbin/insmod usbcore"
| KERNEL: usb.c: registered new driver usbdevfs
| KERNEL: usb.c: registered new driver hub
| | Using /lib/modules/2.4.36/kernel/drivers/usb/usbcore.o
| initrd: +--- Executing "/sbin/insmod usb-uhci"
| KERNEL: usb-uhci.c: $Revision: 1.275 $ time 13:13:26 Jul 22 2008
| KERNEL: usb-uhci.c: High bandwidth mode enabled
| KERNEL: PCI: Setting latency timer of device 00:1f.2 to 64
| KERNEL: usb-uhci.c: USB UHCI at I/O 0xd000, IRQ 3
| KERNEL: usb-uhci.c: Detected 2 ports
| KERNEL: usb.c: new USB bus registered, assigned bus number 1
| KERNEL: hub.c: USB hub found
| KERNEL: hub.c: 2 ports detected
| KERNEL: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
| | Using /lib/modules/2.4.36/kernel/drivers/usb/host/usb-uhci.o
| initrd: +--- Executing "/sbin/insmod usb-ohci"
| initrd: +- Errorlevel: 1, output:
| | insmod: init_module: usb-ohci: No such device
| | ost/usb-ohci.o
| KERNEL: hub.c: new USB device 00:1f.2-1, assigned address 2
| KERNEL: usb.c: USB device 2 (vend/prod 0x1241/0x1166) is not claimed by any active driver.
| KERNEL: hub.c: new USB device 00:1f.2-2, assigned address 3
| KERNEL: usb.c: USB device 3 (vend/prod 0xc2e/0x700) is not claimed by any active driver.
| +--- FILE "/proc/bus/usb/devices" -----------------------
| | T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 2
| | B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
| | D: Ver= 1.00 Cls=09(hub ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
| | P: Vendor=0000 ProdID=0000 Rev= 0.00
| | S: Product=USB UHCI Root Hub
| | S: SerialNumber=d000
| | C:* #Ifs= 1 Cfg#= 1 Atr=40 MxPwr= 0mA
| | I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
| | E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=255ms
| | T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=1.5 MxCh= 0
| | D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
| | P: Vendor=1241 ProdID=1166 Rev= 2.70
| | C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=100mA
| | I: If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=(none)
| | E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=10ms
| | T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 3 Spd=1.5 MxCh= 0
| | P: Vendor=0c2e ProdID=0700 Rev= 1.00
| | S: Manufacturer=Metrologic
| | S: Product=Metrologic Scanner
| | C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=300mA
| | I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
| | E: Ad=02(O) Atr=03(Int.) MxPS= 8 Ivl=10ms
| initrd: Found USB device 1241:1166.
| initrd: Found USB mouse.
| initrd: Found USB device 0c2e:0700.
| initrd: Loading usb Human Interface Device driver.
| initrd: +--- Executing "/sbin/insmod input"
| initrd: +--- Executing "/sbin/insmod hid"
| KERNEL: usb.c: registered new driver hid
| KERNEL: input: USB HID v1.10 Mouse [1241:1166] on usb1:2.0
| KERNEL: hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik <vojtech@suse.cz>
| KERNEL: hid-core.c: USB HID support drivers
| initrd: Loading ethernet drivers.
| initrd: +--- Executing "/sbin/modprobe 8139too"
| KERNEL: eth0: RealTek RTL8139 at 0xc483c000, 00:e0:4c:39:00:28, IRQ 11
| KERNEL: eth0: Identified 8139 chip type 'RTL-8139C'
| KERNEL: eth0: link up, 100Mbps, full-duplex, lpa 0x41E1
| initrd: NIC module 8139too.o loaded.
| initrd: Loading usb mouse driver.
| initrd: +--- Executing "/sbin/insmod mousedev"
| KERNEL: mice: PS/2 mouse device common for all mice
| initrd: +--- Executing "/sbin/udhcpc --script=/sbin/dhcpCB --quit --now --interface=eth0"
| dhcpCB: DHCP command: deconfig.
| dhcpCB: DHCP command: bound.
| dhcpCB: DHCP server: 192.168.0.1.
| dhcpCB: Interface: "eth0".
| dhcpCB: IP: 192.168.0.5.
| dhcpCB: Netmask: 255.255.255.0.
| dhcpCB: TFTP server: 192.168.0.1.
| dhcpCB: Boot file: "pxelinux.0".
| dhcpCB: TFTP prefix: "".
| dhcpCB: Default gateway: 0.0.0.0.
| initrd: Trying to download file "configs/list.wtc" from TFTP server "192.168.0.1".
| initrd: Error code 1: File not found.
| initrd: Trying to download file "configs/00.E0.4C.39.00.28.wtc" from TFTP server "192.168.0.1".
| initrd: Trying to download file "configs/all.wtc" from TFTP server "192.168.0.1".
| initrd: Trying to download file "all.wtc" from TFTP server "192.168.0.1".
| initrd: Trying to download file "wtware.lic" from TFTP server "192.168.0.1".
| initrd: WHOLE CONFIG FILE:
| +--- FILE "/tmp/cfg" -----------------------
| | win2kIP = 192.168.0.1
| | video=i810fb(F)
| | #mouse=usb
| | mouse_wheel = on
| | mouse_accel_mult = 0.9
| | resolution = 1024x768
| | bpp = 16
| | turnoffmenu=always
| | #com1=on
| | com1=usb-serial
| | #com2=usb-serial
| | #com3=usb-serial
| | #com1=on
| | #com2=on
| | #com3=on
| | user=Пользователь_1
| | password=1
| | syslog=192.168.0.1
| | # ┬ Їрщых шёяюы№чєхЄё  DOS-ъюфшЁютър. ─ы  ъюЁЁхъЄэюую
| | # юЄюсЁрцхэш  т Notepad т√схЁшЄх т ьхэ■ "╘юЁьрЄ > ╪ЁшЇЄ"
| | # °ЁшЇЄ "Terminal".
| | # В этот файл складываются лицензии на терминалы. Полные
| | # лицензии необходимо покупать за деньги, подробнее здесь:
| | # http://wtware.ru/buy.html
| | # Лицензии для тестирования, без ограничений по времени,
| | # можно бесплатно получить, заполнив форму:
| | # http://wtware.ru/download.html
| | # Лицензия WTware состоит из пяти строк, которые нужно без
| | # изменений перенести в этот файл. Подробнее про лицензии
| | # читайте здесь:
| | # http://wtware.ru/licensing/terms.html
| initrd: Read config file.
| initrd: Found parameter "win2kIP" with value = "192.168.0.1".
| initrd: Found parameter "video" with value = "i810fb(F)".
| initrd: Found parameter "mouse_wheel" with value = "on".
| initrd: Found parameter "mouse_accel_mult" with value = "0.9".
| initrd: Found parameter "resolution" with value = "1024x768".
| initrd: Found parameter "bpp" with value = "16".
| initrd: Found parameter "turnoffmenu" with value = "always".
| initrd: Found parameter "com1" with value = "usb-serial".
| initrd: Found parameter "user" with value = "Пользователь_1".
| initrd: Found parameter "password" with value.
| initrd: Found parameter "syslog" with value = "192.168.0.1".
| initrd: Use DOS (alt, 866) codepage for config file.
| initrd: Hostname: "wtw00E04C390028".
| initrd: User [╧юы№чютрЄхы№_1], display_name [], domain [], password present.
| initrd: Using video driver Intel i810/i815.
| initrd: +--- Executing "/sbin/udhcpc --script=/sbin/dhcpCB --quit --now --interface=eth0 --hostname=wtw00E04C390028 --request=192.168.0.5"
| Got config from initrd.
initrd: Loading usb <-> serial bridges drivers.
initrd: +--- Executing "/sbin/insmod usbserial"
KERNEL: usb.c: registered new driver serial
KERNEL: usbserial.c: USB Serial Driver core v1.4
initrd: +--- Executing "/sbin/insmod pl2303"
KERNEL: usbserial.c: USB Serial support registered for PL-2303
KERNEL: pl2303.c: Prolific PL2303 USB to serial adaptor driver v0.10.1
initrd: +--- Executing "/sbin/insmod ftdi_sio"
KERNEL: usbserial.c: USB Serial support registered for FTDI SIO
KERNEL: usbserial.c: USB Serial support registered for FTDI 8U232AM Compatible
KERNEL: usbserial.c: USB Serial support registered for FTDI FT232BM Compatible
KERNEL: usbserial.c: USB Serial support registered for FTDI FT2232C Compatible
KERNEL: usbserial.c: USB Serial support registered for FTDI FT232R Compatible
KERNEL: usbserial.c: USB Serial support registered for USB-UIRT Infrared Tranceiver
KERNEL: usbserial.c: USB Serial support registered for Home-Electronics TIRA-1 IR Transceiver
KERNEL: ftdi_sio.c: v1.3.5r1:USB FTDI Serial Converters Driver
initrd: +--- Executing "/sbin/insmod cp210x"
KERNEL: usbserial.c: USB Serial support registered for CP210X
KERNEL: cp210x.c: Silicon Labs CP210x RS232 serial adaptor driver v0.10_2.4-backport
initrd: Loading agpgart driver.
initrd: +--- Executing "/sbin/insmod agpgart"
KERNEL: Linux agpgart interface v0.99 (c) Jeff Hartmann
KERNEL: agpgart: Maximum main memory to use for agp memory: 26M
KERNEL: agpgart: Detected an Intel i810 Chipset.
KERNEL: agpgart: AGP aperture is 64M @ 0xe0000000
initrd: Trying to download file "packages/wtpf.pkg" from TFTP server "192.168.0.1".
initrd: Trying to download file "graphic/menu.gif" from TFTP server "192.168.0.1".
initrd: Trying to download file "graphic/pleasewait.gif" from TFTP server "192.168.0.1".
initrd: Trying to download file "graphic/popup.gif" from TFTP server "192.168.0.1".
init: WTware PRO second shell, v.4.4.16
init: New mode: 1024x768, 16 bit, -1 Hz, modeline "".
init: i810fb: ask for 3 Mb framebuffer.
init: /sbin/modprobe i810fb hsync2=200 xres=1024 yres=768 bpp=16 vram=3 mtrr=1
init: +--- Executing "/sbin/modprobe i810fb hsync2=200 xres=1024 yres=768 bpp=16 vram=3 mtrr=1"
KERNEL: Console: switching to colour frame buffer device 128x48
KERNEL: fb0: Intel(R) 810 Framebuffer Device v0.0.35, Tony Daplas
KERNEL: Video RAM : 3072K
KERNEL: Mode : 1024x768-16bpp@60Hz
KERNEL: Acceleration : disabled
KERNEL: MTRR : enabled
KERNEL: External VGA : disabled
KERNEL: Hardware cursor: disabled
KERNEL: Video Timings : VESA GTF (US)
KERNEL: Memory Tiling : disabled
init: +- Errorlevel: 0, output:
init: +------------------------
init: Kernel framebuffer module loaded.
init: Framebuffer device found.
init: xres 1024, xres_virtual 1024, yres 768, yres_virtual 1536, bits_per_pixel 16
init: VSI.pixclock 15593, sync 00000023
init: left_margin 160, right_margin 56, hsync_len 104
init: upper_margin 23, lower_margin 1, vsync_len 3
init: Framebuffer videomode: 1024x768-16@60.
init: LINELENBYTES 2048
init: VLEN 1572864
init: Allocate 1572864 bytes of shared memory for backscreen, 801 bytes for dirty buffer.
init: Backscreen shared mem Id 00000000.
init: Dirty buffer shared mem Id 00008001.
init: Shared memory for backscreen 401dc000.
init: Shared memory for dirty buffer 40007000.
init: Total free ram: 47764 KB.
init: Bitmap cache sizes: base number: 1729.
init: Free ram after buffers allocation: 15752 KB.
init: Free ram just before session: 19648 Kb.
init: RDP: connecting to "192.168.0.1":3389
init: 192.168.0.1 => 192.168.0.1.
init: Kernel default buffer 87380 bytes.
init: TCP/IP connection with 192.168.0.1:3389 established
pfac: Got command line /sbin/rdpdr[serial] 8.
pfac: Ok, PID 55.
rdpdr[serial]: RDP Serial Port Redirector, WTware PRO v.4.4.16.
init: Send configuration to daemon.
init: Make RDP session
init: username "╧юы№чютрЄхы№_1"
init: password present
init: domain ""
init: shell ""
init: directory ""
init: video 1024x768@16
init: pflags 0000006F
init: keyboard 00000409:00000000
init: hostname "wtw00E04C390028"
init: ipaddr "192.168.0.5"
init: RDP4 encryption (NT4, XP, 2000 and 2003 in remote administration mode).
init: RC4 key 128 bit.
init: Iteration, free RAM 19480 Kb
init: Iteration, free RAM 19472 Kb
init: Iteration, free RAM 19464 Kb
init: Iteration, free RAM 19452 Kb
init: Iteration, free RAM 19440 Kb
init: Iteration, free RAM 19436 Kb
init: Iteration, free RAM 19432 Kb
init: Iteration, free RAM 19408 Kb
init: Iteration, free RAM 19404 Kb
init: Iteration, free RAM 19400 Kb
init: Iteration, free RAM 19396 Kb
init: Iteration, free RAM 19388 Kb
init: Iteration, free RAM 19376 Kb
init: Iteration, free RAM 19368 Kb
init: Iteration, free RAM 19364 Kb
init: Iteration, free RAM 19352 Kb
init: Iteration, free RAM 19348 Kb
init: Iteration, free RAM 19344 Kb
init: Iteration, free RAM 19340 Kb
rdpdr[serial]: rdp/RDPDRDeviceSerial.cpp ( 86), IRPMJCreate: -- ERROR -- Failed to open "/dev/usb-tts/0", errno 19.
init: Iteration, free RAM 19316 Kb
init: Iteration, free RAM 19312 Kb
init: Iteration, free RAM 19304 Kb
init: Iteration, free RAM 19300 Kb
init: Iteration, free RAM 19296 Kb
последняя строчка появляется при открытии окна поиска оборудования в 1С
Re: Терминал IskanderLabs и Metrologic MS9540 USB не работает
К этой штуке нет линуксового драйвера для конвертера из USB в serial. И наверное уже не будет. К сожалению, ничего не можем сделать.
baggio
Сообщение baggio »
имееем Metrologic MS-9540
тип подключения USB
сканер настроен как USB-RS232 converter...
на стандартных настройка оно вроде как работает 9600,8.n,1
но вот как только задаешь префикс суфикс и нестандартную скорость... беда...
Файл настроек сканера + лог Wtware приложен... просьба наставить на путь истенный...
MS-9520_9540_Voyager_RS_SM-2000.zip
Настройки сканера для пониманияю...
(121.26 КБ) 1024 скачивания
WTware_00.01.2E.3A.F1.47_2012-07-25_16-26-14.txt.zip
Логи терминала
(27.82 КБ) 926 скачиваний
Re: Metrologic MS-9540 (2400,e,7,2)
В логе строка:
16-25-27-0906| | P: Vendor=0c2e ProdID=0700 Rev= 1.00
0700 - это режим клавиатуры. Или еще чего-то. Но это НЕ режим эмуляции ком-порта.
Надо читать методичку (возможно, стоит скачать настоящую английскую методичку) и сканировать коды настроек до тех пор, пока в логе не станет написано ProdID=0720.
baggio
Сообщение baggio »
Возможно я бы согласился... но...
это режим ком порта... возможно старых ревизий...
дело в том что пробросив его через usb-ip (он пока единственный терминал на пробу поэтому пока можно) и установив драйвера на виндовом сервере он кстати встал как ком порт... все заработало... т.е. дело однозначно в связке Wtware+Scaner+его настройки...
Перед тем как отдать настроенный терминал (настраивал я его под рукой и проверял ТОЧНО такой же сканер на 9600 он прекрасно работал) я проверил всё что мог... но не думал что тут может быть засада... я всегда думал что если компорт пашет то пофиг с какими настройками а тут нате...
По поводу родной книжицы это конечно хорошо но поверьте это правильные настройки , С их помощью я настроил несколько тысяч сканеров и они нормально работают... Второе это то что сканер сейчас от меня далеко и объеснять обезъяне с гранатой как сканировать ШК для настройки сканера то ещё удовольствие...
Завершая опус... скажите что мне сделать и что мне Вам дать чтобы Вы могли более детально изучить проблему и решить её?
baggio писал(а):Возможно я бы согласился... но...
Теперь перепрограммируй сканер в режим эмуляции usb-клавиатуры. Виндовый драйвер останется работать как ком-порт?
baggio писал(а):По поводу родной книжицы это конечно хорошо но поверьте это правильные настройки , С их помощью я настроил несколько тысяч сканеров и они нормально работают
С линуксовым драйвером сколько из них работают?
baggio писал(а):что мне сделать и что мне Вам дать чтобы Вы могли более детально изучить проблему и решить её?
Пришли нам один сканер. Я выложу для тебя код, который надо отсканировать чтобы сканер стал Vendor=0c2e ProdID=0720 и заработал с линуксовым драйвером. Но сканер потом обратно не верну :)
baggio
Сообщение baggio »
Итак правда как оказалось "посередине"
Сканеры метролоджик могут работать в режиме компорта в дух вариантах
Uni-directional - это как раз код Vendor=0c2e ProdID=0700
и
bi-directional это как раз код Vendor=0c2e ProdID=0720
так вот в режиме Uni-directional сканер с WTware работает НЕ КОРРЕКТНО...
поэтому используйте режим bi-directional
Шк для настройки во вложении
Metrologic9540_wtware.rar
(10.06 КБ) 1048 скачиваний
Через пару дней должна выйти 5.1.19 версия втвари. Попробуй пожалуйста ее в режиме uni-direction. В ней свежее линуксовое ядро, и там в драйвере метролоджика исправили ProdID для UNI режима с 0710 (которого я никогда не видел) на 0700. Может, заработает на UNI?
KenI-DeyL
Сообщение KenI-DeyL »
Добрый День. Подниму тему в связи с тем что имеется несколько сканеров данной модели и есть нужда в расширении терминалов и было принято решение об использовании WTware на них, интересует вопрос инструкция "для чайника" по настройке
Заранее благодарю.
1. Научиться перенаправлять сканер через перенаправление com-порта с виндовса на виндовс, через mstsc.exe, без втвари.
2. Взять свежую втварь.
3. Написать в конфиге:
serial=com5(usb)
Если не получится обратиться из сессии к com5, выложить лог.
KenI-DeyL
Большое спасибо!
Даже учиться не пришлось....
Код:
serial=comX(usb) где Х это мой порт установленный в 1с
и команда подключения должна быть последней)))
