Не определяются USB флешка
censor
Сообщение censor »
Добрый день,
первая тема создана без авторизации, прошу ее удалить.
При подключении флешки в логах следующее
09-52-25-0207| [rdpclient 531] RDP Terminal Client, WTware v.5.1.39, pipe 1, pid 531.
09-52-25-0207| [rdpclient 531] Make RDP session with 192.168.0.5:3389.
09-52-25-0207| [rdpclient 531]  Username: "manager_15".
09-52-25-0207| [rdpclient 531]  Password: present.
09-52-25-0207| [rdpclient 531]  Domain: "main".
09-52-25-0207| [rdpclient 531]  No shell.
09-52-25-0207| [rdpclient 531]  No directory.
09-52-25-0207| [rdpclient 531]  Window: 1366x768@16.
09-52-25-0207| [rdpclient 531]  PFlags 0x0000006F.
09-52-25-0207| [rdpclient 531]  Keyboard 00000409:00000000.
09-52-25-0207| [rdpclient 531]  My hostname "wtw00012E3BCC47".
09-52-25-0207| [rdpclient 531] TCP: connecting to 192.168.0.5:3389.
09-52-25-0207| [rdpclient 531] TCP: connection with 192.168.0.5:3389 established.
09-52-25-0207| [rdpclient 531] Turn keepalive on.
09-52-25-0207| [rdpclient 531] Free ram after buffers allocation: 2043260 KB.
09-52-25-0207| [rdpclient 531] RDP5 encryption (X.509).
09-52-25-0207| [rdpclient 531] RC4 key 128 bit.
09-52-25-0207| [KERNEL] scsi 1:0:0:0: Direct-Access              silicon-power    PMAP PQ: 0 ANSI: 0 CCS
09-52-25-0207| [KERNEL] scsi 0:0:0:0: Direct-Access     Generic- Multi-Card       1.00 PQ: 0 ANSI: 0 CCS
09-52-25-0207| [KERNEL] sd 1:0:0:0: [sda] 7831552 512-byte logical blocks: (4.00 GB/3.73 GiB)
09-52-25-0207| [KERNEL] sd 1:0:0:0: [sda] Write Protect is off
09-52-25-0207| [KERNEL] sd 1:0:0:0: [sda] Mode Sense: 23 00 00 00
09-52-25-0207| [KERNEL] sd 1:0:0:0: [sda] No Caching mode page present
09-52-25-0207| [KERNEL] sd 1:0:0:0: [sda] Assuming drive cache: write through
09-52-25-0207| [KERNEL] sd 0:0:0:0: [sdb] Attached SCSI removable disk
09-52-25-0207| [KERNEL]  sda:
09-52-25-0207| [hotplug] Action change.
09-52-25-0207| [KERNEL] sd 1:0:0:0: [sda] Attached SCSI removable disk
09-52-25-0207| [hotplug] R/w FAT mount ("/dev/sdb", "/mnt/usb-smb/USB2raw",..) failed, errno 123.
09-52-25-0207| [hotplug] Success: USB1raw mounted.
09-52-25-0207| [KERNEL] FAT-fs (sda): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
09-52-25-0207| [hotplug] R/o NTFS mount ("/dev/sdb", "/mnt/usb-smb/USB2raw",..) failed, errno 123.
09-52-25-0207| [hotplug] R/o FAT mount ("/dev/sdb", "/mnt/usb-smb/USB2raw",..) failed, errno 123.
09-52-25-0207| [rdpclient 531] SessionId 0x0000000d: MAIN\manager_15.
09-52-25-0208| Connection from wtc.exe at 192.168.0.5.
Это в логах если вынуть предыдущую флешку и вставить другую
09-59-07-0346| [KERNEL] usb 1-7: USB disconnect, device number 5
09-59-07-0550| [hotplug] /dev/sda unmounted from /mnt/usb-smb/USB1raw.
09-59-11-0693| [KERNEL] usb 1-7: new high-speed USB device number 6 using ehci-pci
09-59-11-0889| [KERNEL] usb 1-7: New USB device found, idVendor=13fe, idProduct=1d00
09-59-11-0891| [KERNEL] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
09-59-11-0891| [KERNEL] usb 1-7: Product: DataTraveler 2.0
09-59-11-0893| [KERNEL] usb 1-7: Manufacturer: Kingston
09-59-11-0893| [KERNEL] usb 1-7: SerialNumber: 5B7303AD6FC1
09-59-11-0895| [KERNEL] scsi2 : usb-storage 1-7:1.0
09-59-12-0814| [KERNEL] scsi 2:0:0:0: Direct-Access     Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 0 CCS
09-59-13-0450| [KERNEL] sd 2:0:0:0: [sda] 2015232 512-byte logical blocks: (1.03 GB/984 MiB)
09-59-13-0461| [KERNEL] sd 2:0:0:0: [sda] Write Protect is off
09-59-13-0463| [KERNEL] sd 2:0:0:0: [sda] Mode Sense: 23 00 00 00
09-59-13-0464| [KERNEL] sd 2:0:0:0: [sda] No Caching mode page present
09-59-13-0466| [KERNEL] sd 2:0:0:0: [sda] Assuming drive cache: write through
09-59-13-0466| [KERNEL] sd 2:0:0:0: [sda] No Caching mode page present
09-59-13-0468| [KERNEL] sd 2:0:0:0: [sda] Assuming drive cache: write through
09-59-13-0469| [KERNEL]  sda: sda1
09-59-13-0471| [hotplug] R/w FAT mount ("/dev/sda", "/mnt/usb-smb/USB1raw",..) failed, errno 22.
09-59-13-0471| [KERNEL] FAT-fs (sda): invalid media value (0x00)
09-59-13-0473| [KERNEL] FAT-fs (sda): Can't find a valid FAT filesystem
09-59-13-0474| [hotplug] R/o NTFS mount ("/dev/sda", "/mnt/usb-smb/USB1raw",..) failed, errno 22.
09-59-13-0476| [KERNEL] sd 2:0:0:0: [sda] No Caching mode page present
09-59-13-0476| [KERNEL] sd 2:0:0:0: [sda] Assuming drive cache: write through
09-59-13-0478| [KERNEL] sd 2:0:0:0: [sda] Attached SCSI removable disk
09-59-13-0479| [KERNEL] NTFS-fs warning (device sda): is_boot_sector_ntfs(): Invalid boot sector checksum.
09-59-13-0480| [KERNEL] NTFS-fs error (device sda): read_ntfs_boot_sector(): Primary boot sector is invalid.
09-59-13-0481| [KERNEL] NTFS-fs error (device sda): read_ntfs_boot_sector(): Mount option errors=recover not used. Aborting without trying to recover.
09-59-13-0483| [KERNEL] NTFS-fs error (device sda): ntfs_fill_super(): Not an NTFS volume.
09-59-13-0483| [hotplug] R/o FAT mount ("/dev/sda", "/mnt/usb-smb/USB1raw",..) failed, errno 22.
09-59-13-0485| [KERNEL] FAT-fs (sda): invalid media value (0x00)
09-59-13-0485| [KERNEL] FAT-fs (sda): Can't find a valid FAT filesystem
09-59-13-0664| [hotplug] Success: USB1p1 mounted.
в "Компьютер" не видно ни первой, ни второй. Прошу подсказать, в чем проблема?
Спасибо.
censor
Re: Не определяются USB флешка
Сообщение censor »
версия 5.1.39
Терминальный сервер Windows 2008 R2
Prizrak
Сообщение Prizrak »
Я думаю, ошибка в этом
censor писал(а):в "Компьютер" не видно ни первой, ни второй. Прошу подсказать, в чем проблема?
В том, что никто не читает документацию :( Через параметр shared_disk= оно не должно вылазить в "Компьютер". В "Компьютер" оно должно вылазить через disk=, но даже это не гарантируется. Смотри документацию, она рулез.
icy
Сообщение icy »
Версия 5.1.40 пропали usb flash. Кусок лога с терминала:
16-52-16-0612| [KERNEL] usb 1-2: new high-speed USB device number 3 using ehci-pci
16-52-16-0612| [KERNEL] usb 1-2: New USB device found, idVendor=1687, idProduct=6211
16-52-16-0612| [KERNEL] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
16-52-16-0612| [KERNEL] usb 1-2: Product: USB2.0 FlashDisk
16-52-16-0612| [KERNEL] usb 1-2: Manufacturer: Kingmax
16-52-16-0612| [KERNEL] usb 1-2: SerialNumber: 20080125000000000000276C
16-52-16-0612| [KERNEL] usb-storage 1-2:1.0: USB Mass Storage device detected
16-52-16-0612| [KERNEL] scsi0 : usb-storage 1-2:1.0
16-52-16-0612| [KERNEL] scsi 0:0:0:0: Direct-Access Kingmax USB2.0 FlashDisk 1.00 PQ: 0 ANSI: 2
16-52-16-0612| [KERNEL] sd 0:0:0:0: [sda] 15933440 512-byte logical blocks: (8.15 GB/7.59 GiB)
16-52-16-0612| [KERNEL] sd 0:0:0:0: [sda] Write Protect is off
16-52-16-0612| [KERNEL] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
16-52-16-0612| [KERNEL] sd 0:0:0:0: [sda] No Caching mode page present
16-52-16-0612| [KERNEL] sd 0:0:0:0: [sda] Assuming drive cache: write through
16-52-16-0612| [KERNEL] usb 1-2: USB disconnect, device number 3
16-52-16-0612| [KERNEL] sd 0:0:0:0: [sda] Attached SCSI removable disk
16-52-16-0612| [hpsc] fstream.cpp ( 461), openWithTimeout: -- ERROR -- INTERNAL ERROR (2). Please, contact WTware tech support.
16-52-16-0612| [hpsc] misc2.cpp ( 262), read_int: -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
16-52-16-0612| [hpsc] diskDevice.cpp ( 107), disk_checkUSBFloppy: -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
16-52-16-0612| [hpsc] diskDevice.cpp ( 407), mount_RDPDR: -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
Ядро утверждает, что ты подключил и сразу же отключил устройство, оно еще не успело с ним толком снюхаться.
Покажи лог целиком. И лог ЭТОЙ ЖЕ флешки на прежней версии втвари, когда оно еще работало, желательно на этом же терминале.
icy
Сообщение icy »
Все-таки проблема оказалась в флешке. Windows нормально с ней сотрудничает, wtware - не хочет. Другие флешки работают нормально.
